I am wondering if cuda-gdb is able to execute a script of debug code as gdb. Is there any difference if it is able to?
Hi @Ziqi
cuda-gdb
supports executing the debugging scripts (same as gdb
All gdb functionality is supported. Additionally CUDA specific command can be used in the scripts: CUDA-GDB
Thanks. Too many variables are optimized even thought -G
is provided. This optimization for debug build really damages experience of cuda-gdb
. Is there any plan to prevent unnecessary optimization in NVCC group?
We can pass along this information to the compiler group, but a specific use case would make it easier to triage. Do you have an example you can share?
Unfortunately, anything related to our source code cannot be revealed. The only thing I can share is our building info:
Compiling ../ArrayMPA/src/mpa_utility.cu to make object file ../ArrayMPA/Debug/mpa_utility.x86-64.o.
nvcc -x cu --compiler-options "-fPIC" --expt-relaxed-constexpr --gpu-architecture=sm_86 -Xcudafe --display_error_number -DPREFETCH=0 -DUSE_DCBX=0 -DX86 -D_LITTLE_ENDIAN_=1 -D__LITTLE_ENDIAN__=1 -DCPLUSPLUS_2011 -DDEBUG=2 -DDETECTION_DEBUG -DCHECKCUDAERROR -DGOOGLE_CUDA=1 -D_MWAITXINTRIN_H_INCLUDED -D_FORCE_INLINES -DUNIT_TEST=1 -g -G -O0 -I../../../../../../../../../../../../../usr/local/include -I../ArrayMPA -I../ArrayMPA/include -I../../../../../../../../../../../../../usr/local/cuda/targets/x86_64-linux/include -I/usr/local/lib/python3.8/dist-packages/tensorflow/include -D_GLIBCXX_USE_CXX11_ABI=1 -DEIGEN_MAX_ALIGN_BYTES=64 -I ../../../../scripts/../3dparty/libpng -I ../../../../scripts/../3dparty/zlib -I../../../ops/CommonUtils//../..//shared -I../../../ops/CommonUtils//../..//ops/CommonUtils -I../../../ops/CommonUtils//../..//ops/CommonUtils/Png --keep --keep-dir ../ArrayMPA/Debug -c ../ArrayMPA/src/mpa_utility.cu -o ../ArrayMPA/Debug/mpa_utility.x86-64.o
Clearly I used -g -G -O0
in compilation. However, within cuda-gdb, as I printed a variable using p interpCtr
, I got $1 = <optimized out>
Maybe this is a project the NVCC group and the cuda-gdb group should collaborate on :) The collaboration will lead to good performance review :)
Surprisingly, I do not see many people complaining about the issue. Maybe not too many people really use cuda-gdb in development?
