cuda-gdb 12.6
OS:Ubuntu 24.04.2 LTS
Hardware architecuture: A100 sm_80
Code:
#include <cuda_fp16.h>
#include <cuda_runtime.h>
#include <stdio.h>
#include <stdint.h>
#define CHECK_CUDA(call) \
if ((call) != cudaSuccess) { \
fprintf(stderr, "CUDA error at %s:%d: %s\n", __FILE__, __LINE__, cudaGetErrorString(call)); \
exit(EXIT_FAILURE); \
#define OFFSET(i, j, ld) (((i) * (ld)) + (j))
#define FETCH_FLOAT4(ptr) (*reinterpret_cast<float4 *>(&(ptr)))
#define WARP_SIZE 32
template <const int BM, const int BN>
__global__ void mma_m16n8k16_ptx2(half* A, half* B, int M, int N, int K, float* C) {
const int WARP_N = BN / 8;
const int WRAP_ID = threadIdx.x / WARP_SIZE;
const int LANE_ID = threadIdx.x % WARP_SIZE;
const int WARP_ROW = WRAP_ID / WARP_N;
const int WARP_COL = WRAP_ID % WARP_N;
const int C_THREAD_ROW = LANE_ID / 4;
const int C_THREAD_COL = LANE_ID % 4;
float c[4] = {0.0, 0.0, 0.0, 0.0};
__shared__ half s_a[BM][16];
__shared__ half s_b[16][BN];
uint32_t ra[4];
uint32_t rb[2];
const int WARP_ROW_OFFSET_A = WARP_ROW * 16;
const int WARP_COL_OFFSET_B = WARP_COL * 8;
const int WARP_ROW_OFFSET_C = WARP_ROW * 16 + blockIdx.y * BM;
const int WARP_COL_OFFSET_C = WARP_COL * 8 + blockIdx.x * BN;
const int BLOCK_ROW_OFFSET = blockIdx.y * BM;
const int BLOCK_COL_OFFSET = blockIdx.x * BN;
const int NUM_ELEMENT_PER_THREAD = sizeof(float4) / sizeof(half);
const int ROW_OFFSET_A = threadIdx.x * NUM_ELEMENT_PER_THREAD / 16;
const int COL_OFFSET_A = (threadIdx.x * NUM_ELEMENT_PER_THREAD) % 16;
const int ROW_STRIDE_A = blockDim.x * NUM_ELEMENT_PER_THREAD / 16;
const int ROW_OFFSET_B = threadIdx.x * NUM_ELEMENT_PER_THREAD / BN;
const int COL_OFFSET_B = (threadIdx.x * NUM_ELEMENT_PER_THREAD) % BN;
const int ROW_STRIDE_B = blockDim.x * NUM_ELEMENT_PER_THREAD / BN;
for (int i = 0; i < K; i += 16) {
for (int offset = 0; offset < BM; offset += ROW_STRIDE_A) {
if (offset + ROW_OFFSET_A < BM) {
FETCH_FLOAT4(s_a[offset + ROW_OFFSET_A][COL_OFFSET_A]) =
FETCH_FLOAT4(A[OFFSET(BLOCK_ROW_OFFSET + offset + ROW_OFFSET_A, COL_OFFSET_A + i, K)]);
for (int offset = 0; offset < 16; offset += ROW_STRIDE_B) {
if (offset + ROW_OFFSET_B < 16) {
FETCH_FLOAT4(s_b[offset + ROW_OFFSET_B][COL_OFFSET_B]) =
FETCH_FLOAT4(B[OFFSET(i + offset + ROW_OFFSET_B, BLOCK_COL_OFFSET + COL_OFFSET_B, N)]);
__syncthreads();
uint32_t addr_a = __cvta_generic_to_shared(&s_a[WARP_ROW_OFFSET_A + LANE_ID % 16][(LANE_ID / 16) * 8]);
uint32_t addr_b = __cvta_generic_to_shared(&s_b[LANE_ID % 16][WARP_COL_OFFSET_B]);
asm volatile("ldmatrix.sync.aligned.x4.m8n8.shared.b16 {%0, %1, %2, %3}, [%4];"
: "=r"(ra[0]), "=r"(ra[1]), "=r"(ra[2]), "=r"(ra[3])
: "r"(addr_a));
if (LANE_ID < 16) {
asm volatile("ldmatrix.sync.aligned.x2.m8n8.shared.b16 {%0, %1}, [%2];"
: "=r"(rb[0]), "=r"(rb[1])
: "r"(addr_b));
asm("mma.sync.aligned.m16n8k16.row.col.f32.f16.f16.f32 "
" { %0, %1, %2, %3 }, "
" { %4, %5, %6, %7 }, "
" { %8, %9 }, "
" { %0, %1, %2, %3 };"
: "+f"(c[0]), "+f"(c[1]), "+f"(c[2]), "+f"(c[3])
: "r"(ra[0]), "r"(ra[1]), "r"(ra[2]), "r"(ra[3]), "r"(rb[0]), "r"(rb[1]));
__syncthreads();
C[OFFSET(WARP_ROW_OFFSET_C + C_THREAD_ROW, WARP_COL_OFFSET_C + C_THREAD_COL * 2, N)] = c[0];
C[OFFSET(WARP_ROW_OFFSET_C + C_THREAD_ROW, WARP_COL_OFFSET_C + C_THREAD_COL * 2 + 1, N)] = c[1];
C[OFFSET(WARP_ROW_OFFSET_C + C_THREAD_ROW + 8, WARP_COL_OFFSET_C + C_THREAD_COL * 2, N)] = c[2];
C[OFFSET(WARP_ROW_OFFSET_C + C_THREAD_ROW + 8, WARP_COL_OFFSET_C + C_THREAD_COL * 2 + 1, N)] =
c[3];
int main() {
int M = 128;
int N = 128;
int K = 128;
size_t size_A = M * K * sizeof(half);
size_t size_B = K * N * sizeof(half);
size_t size_C = M * N * sizeof(float);
half *h_A = (half *)malloc(size_A);
half *h_B = (half *)malloc(size_B);
float *h_C = (float *)malloc(size_C);
for (int i = 0; i < M * K; ++i)
h_A[i] = __float2half(1.0f);
for (int i = 0; i < K * N; ++i)
h_B[i] = __float2half(1.0f);
half *d_A, *d_B;
float *d_C;
CHECK_CUDA(cudaMalloc(&d_A, size_A));
CHECK_CUDA(cudaMalloc(&d_B, size_B));
CHECK_CUDA(cudaMalloc(&d_C, size_C));
CHECK_CUDA(cudaMemcpy(d_A, h_A, size_A, cudaMemcpyHostToDevice));
CHECK_CUDA(cudaMemcpy(d_B, h_B, size_B, cudaMemcpyHostToDevice));
CHECK_CUDA(cudaMemset(d_C, 0, size_C));
const int BM = 32;
const int BN = 32;
const int WARP_NUM = (BM * BN) / (16 * 8);
const dim3 block_dim(WARP_NUM * WARP_SIZE);
const dim3 grid_dim(N / BN, M / BM);
mma_m16n8k16_ptx2<BM, BN><<<grid_dim, block_dim>>>(d_A, d_B, M, N, K, d_C);
CHECK_CUDA(cudaDeviceSynchronize());
CHECK_CUDA(cudaMemcpy(h_C, d_C, size_C, cudaMemcpyDeviceToHost));
printf("C[0][0] = %f\n", h_C[OFFSET(0, 0, N)]);
printf("C[1][0] = %f\n", h_C[OFFSET(1, 0, N)]);
printf("C[0][1] = %f\n", h_C[OFFSET(0, 1, N)]);
cudaFree(d_A);
cudaFree(d_B);
cudaFree(d_C);
free(h_A);
free(h_B);
free(h_C);
return 0;
When executing this code, the debugger gets stuck at the line containing the mma instruction.
I wonder why this happens
