Hi all,
I encountered a CUDA graph replay hang issue when cross-green-context edges are used. It only happens on the R610 driver or CUDA 13.3. The same code runs to completion on R580, and it also completes when not using green context. Using containers with other CUDA versions on R610 driver hangs too.
Setup
The graph has three kernels on two streams. Each stream comes from its own green context, made by splitting the device’s SMs:
stream A (green ctx, 64 SMs): kernel a ---------+
| (event)
v
stream B (green ctx, rest) : kernel b ----> kernel c
Kernel c depends on a (an event edge that crosses partitions) and on b (same stream).
- Eager execution completes every time.
- On the first
graph.replay(),aandbrun butcnever does (verified with a triton kernel version running a print statement, and c never prints; repro code below doesn’t use triton to keep it minimal) - With
--green 0, the script uses ordinarytorch.cuda.Stream()s and all 10 replays complete.
Environment
| Result | |
| R610 driver, CUDA UMD 13.3 | Hangs |
| Driver 580.95.05, CUDA 13.0 | Works |
- Container:
nvcr.io/nvidia/pytorch:26.02-py3(CUDA 13.1.1). The same container hangs on R610 and works on R580. Other containers with different CUDA versions also hang on R610, so the trigger looks like the driver, not the toolkit. - GPU:
<GPU model>(132 SMs, split 64 + 68)
NVIDIA-SMI on an R610 environment with H200 where it hangs:
| NVIDIA-SMI 610.57.04 KMD Version: 610.57.04 CUDA UMD Version: 13.3 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA H200 On | 00000000:64:00.0 Off | 0 |
| N/A 26C P0 74W / 700W | 4MiB / 143771MiB | 0% Default |
| | | Disabled |
| Processes: |
| ID ID Usage |
| No running processes found |
Repro Code:
"""Three-kernel CUDA graph that hangs on its first replay with green-context streams.
| (event)
v
Kernel c depends on a (cross-partition edge) and b (same-stream edge). Eager runs
complete; the first graph.replay() runs a and b, never c, and the following
synchronize blocks forever. --green 0 uses ordinary streams and passes.
python repro-3kernel-green-graph-hang.py # hangs after "replay 1"
python repro-3kernel-green-graph-hang.py --green 0 # prints ALL DONE
import argparse
import sys
import time
import torch
from cuda.bindings import driver
def dummy_kernel(x):
x.zero_()
def check(ret):
err, *vals = ret
assert err == driver.CUresult.CUDA_SUCCESS, err
return vals[0] if len(vals) == 1 else vals
def green_stream(cu_dev, resource):
desc = check(driver.cuDevResourceGenerateDesc([resource], 1))
ctx = check(
driver.cuGreenCtxCreate(
desc, cu_dev, driver.CUgreenCtxCreate_flags.CU_GREEN_CTX_DEFAULT_STREAM
stream = check(
driver.cuGreenCtxStreamCreate(
ctx, driver.CUstream_flags.CU_STREAM_NON_BLOCKING, 0
return torch.cuda.get_stream_from_external(stream)
def main():
p = argparse.ArgumentParser()
p.add_argument("--green", type=int, default=1, choices=[0, 1])
p.add_argument("--sms", type=int, default=64)
p.add_argument("--iters", type=int, default=10)
args = p.parse_args()
torch.cuda.set_device(0)
torch.zeros(1, device="cuda")
if args.green:
cu_dev = check(driver.cuDeviceGet(0))
sm_resource = check(
driver.cuDeviceGetDevResource(
cu_dev, driver.CUdevResourceType.CU_DEV_RESOURCE_TYPE_SM
groups, _, remaining = check(
driver.cuDevSmResourceSplitByCount(1, sm_resource, 0, args.sms)
A = green_stream(cu_dev, groups[0])
B = green_stream(cu_dev, remaining)
print(
f"green ctx streams: A={groups[0].sm.smCount} SMs, B={remaining.sm.smCount} SMs",
flush=True,
else:
A, B = torch.cuda.Stream(), torch.cuda.Stream()
bufs = [torch.zeros(1024, dtype=torch.int32, device="cuda") for _ in range(3)]
def fwd():
cur = torch.cuda.current_stream()
A.wait_stream(cur)
B.wait_stream(cur)
with torch.cuda.stream(A):
dummy_kernel(bufs[0])
a_done = torch.cuda.Event()
a_done.record(A)
with torch.cuda.stream(B):
dummy_kernel(bufs[1])
B.wait_event(a_done)
dummy_kernel(bufs[2])
cur.wait_stream(A)
cur.wait_stream(B)
def sync(label):
print(f"{time.strftime('%H:%M:%S')} {label}: synchronize", flush=True)
torch.cuda.synchronize()
for i in range(5):
fwd()
sync(f"eager {i + 1}")
graph = torch.cuda.CUDAGraph()
with torch.cuda.graph(graph):
fwd()
sync("capture")
for i in range(args.iters):
graph.replay()
sync(f"replay {i + 1}")
print("ALL DONE", flush=True)
return 0
if __name__ == "__main__":
sys.exit(main())
Output with green contexts (hangs on R610):
green ctx streams: A=64 SMs, B=68 SMs
03:25:48 eager 1: synchronize
03:25:48 eager 2: synchronize
03:25:48 eager 3: synchronize
03:25:48 eager 4: synchronize
03:25:48 eager 5: synchronize
03:25:48 capture: synchronize
03:25:48 replay 1: synchronize
<never returns>
Output with --green 0 (passes):
03:28:12 eager 1: synchronize
03:28:12 capture: synchronize
03:28:12 replay 1: synchronize
03:28:12 replay 10: synchronize
ALL DONE
Questions
- Is this a known driver bug in R610? And is there a recommended workaround on R610 that keeps both green contexts and CUDA graphs?
- Is an event dependency between streams in different green contexts officially supported inside one captured graph?
