CUDA Green Context API | Memory Footprint
Description
I monitored the memory footprint on the GPU when using the CUDA green context API.
Observation
Creating a green context increases the memory footprint on the GPU – this is expected.
But when the green context is destroyed with cuGreenCtxDestroy(), the allocated memory on GPU is not / only partly freed.
I checked the amount of leaking memory across different CUDA versions.
Using versions 12.6, 12.8 and 13.0 allocate ~4MiB per green context and do not free any of that memory on destruction.
I created a minimal working example to reproduce this:
#include "cuda.h"
#include "cuda_runtime.h"
#include <cassert>
#include <cstdint>
#include <iostream>
#include <vector>
static uint64_t GetMemoryUsage() {
  uint64_t free_byte = 0;
  uint64_t total_byte = 0;
  auto cuda_status = cudaMemGetInfo(&free_byte, &total_byte);
  return (total_byte - free_byte) / 1000000;
int main(int /*argc*/, const char * /*argv*/[]) {
  cudaDeviceProp device_properties{};
  CUdevResource full_gpu;
  cudaGetDeviceProperties(&device_properties, 0);
  cuDeviceGetDevResource(0, &full_gpu, CU_DEV_RESOURCE_TYPE_SM);
  // Assume the minimum SM count per green context is 4.
  uint32_t minimum_sm_count = 4;
  uint32_t split_count =
      device_properties.multiProcessorCount / minimum_sm_count;
  auto resources = std::vector<CUdevResource>(split_count);
  // Split "full_gpu" into "split_count" SM partitions, each of size
  // "minimum_sm_count".
  cuDevSmResourceSplitByCount(
      resources.data(), &split_count, &full_gpu, nullptr,
      CU_DEV_SM_RESOURCE_SPLIT_IGNORE_SM_COSCHEDULING, minimum_sm_count);
  std::cout << "initial memory footprint=" << GetMemoryUsage() << std::endl;
  for (uint32_t i = 0; i < split_count; ++i) {
    CUgreenCtx green_context = nullptr;
    // Create a resource descriptor.
    CUdevResourceDesc resource_descriptor = nullptr;
    cuDevResourceGenerateDesc(&resource_descriptor, resources.data() + i, 1);
    cuGreenCtxCreate(&green_context, resource_descriptor, 0,
                     CU_GREEN_CTX_DEFAULT_STREAM);
    CUcontext context = nullptr;
    assert(cuCtxFromGreenCtx(&context, green_context) == CUDA_SUCCESS);
    assert(cuGreenCtxDestroy(green_context) == CUDA_SUCCESS);
    // The memory footprint keeps growing although the context is destroyed.
    std::cout << "i=" << i << " memory footprint=" << GetMemoryUsage()
              << std::endl;
  return 0;
Is this expected behavior?
I suggest filing a bug.
This maps to NVBUG 5668693. Thanks to our CUDA engineering team. This is fixed and verified internally with your producer to us. The fix will be targeting a future CUDA 13.3 release bundled driver series.
Thanks again for reaching out to us.
initial memory footprint=187
i=0 memory footprint=190
i=1 memory footprint=190
i=2 memory footprint=190
i=3 memory footprint=190
i=4 memory footprint=190
i=5 memory footprint=190
i=6 memory footprint=190
i=7 memory footprint=190
i=8 memory footprint=190
i=9 memory footprint=190
i=10 memory footprint=190
i=11 memory footprint=190
