I can’t make cuDNN work with theano. (I use OSX 10.9)
Here is the error:
Theano can not compile with cuDNN. We got this error:
clang: warning: treating ‘c’ input as ‘c++’ when in C++ mode, this behavior is deprecated
/var/folders/4s/rbfh6g_94jl3ztjyw8d1wb4h0000gn/T/try_flags_d0Ur73.c:4:10:
fatal error: ‘cuda.h’ file not found
#include <cuda.h>
Actually, Theano is looking for cuda.h in
/lib/Frameworks/Cuda.Framework/Versions/A/Headers/. (it finds it if I
include <cuda/cuda.h>).
How can I make it look for it in /usr/local/cuda/include ?
I’ve installed the Developer version of Theano. I’ve installed CUDA 6.5 and
copied the cudnn files in the directory /usr/local/cuda/lib
(and/usr/local/cuda/include). A friend did the same thing and it works, I don’t what happens.
Here is my .zshrc
export PYLEARN2_DATA_PATH=/Users/Adrien/Documents/projet2a/friesnsteaks/data/
export PYLEARN2_VIEWER_COMMAND=“open -Wn”
export
PATH="/Users/Adrien/Documents/framework/pylearn2/pylearn2/scripts:$PATH"
export PYTHONPATH=$PYTHONPATH:/Users/Adrien/Documents/projet2a/
GPU
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/cuda/lib
#export PATH="/usr/local/cuda:$PATH"
export CUDA_ROOT="/usr/local/cuda/bin:$PATH"
export PATH="/Developer/NVIDIA/CUDA-6.5/bin:$PATH"
export
THEANO_FLAGS=mode=FAST_RUN,device=gpu,floatX=float32,optimizer_including=cudnn,exception_verbosity=high
Any ideas please ?
