Hi all,
I find that every time I use a background thread to execute a CUDA function, I leak one Semaphore handle and one Mutant handle (as seen by the Microsoft Sysinternals tool ‘Handle’, Handle - Windows Sysinternals | Microsoft Docs).
Eventually, I run out of handles and my app dies.
I’m using MS Visual C++ 2008 Pro (on Windows XP, 32-bit) and the CUDA Toolkit 3.2 from January 2011. I had the same problem with toolkit ver. 2.3.
Any ideas why this is happening? I enclose a code snippet below, which is also contained within the attachment.
James
//----------cudafuncs.h-----------------
#ifndef CUDAFUNCS_H_INCLUDED
#define CUDAFUNCS_H_INCLUDED
int RunCudaTest(void);
void ShutdownCuda(void);
#endif //CUDAFUNCS_H_INCLUDED
//---------------cudafuncs.cu-------------
#include “cudafuncs.h”
int
RunCudaTest(void)
cudaSetDevice(0);
unsigned char* d_pBuf = NULL;
int nBufSize = 1000;
cudaMalloc((void**)&d_pBuf, nBufSize);
cudaFree(d_pBuf);
return 0;
}// RunCudaTest
void
ShutdownCuda(void)
cudaThreadExit();
return;
//-------------main.cpp-----------------------
#include
#include
#include <windows.h>
int gDone; ///< Global variable used to wait for thread to finish
- Function that is executed in the background thread. It calls
- a couple of CUDA routines.
DWORD WINAPI WorkingFunction(LPVOID pv)
RunCudaTest();
ShutdownCuda();
gDone = 1;
return 0;
- Function that invokes ‘WorkingFunction’ on a background thread
void RunInBkgThread(HANDLE& hThr)
DWORD lThreadID;
hThr = CreateThread(NULL, 0, WorkingFunction, NULL,
THREAD_PRIORITY_NORMAL, &lThreadID);
return;
}// RunInBkgThread
Main program
int main(int argc, char argv)
HANDLE hThr;// Go through several iterations and watch the number
// of Semaphore and Mutant handles grow…
for (int i = 0; i < 25; ++i)
gDone = 0;
// Run, then loop till it finishes
RunInBkgThread(hThr);
while (0 == gDone)
Sleep(20);
}// Cleanup resources CloseHandle(hThr); int p = 4;
}// i loop over trials
return 0;
}// main
cudaHandleLeak.zip (3.33 KB)
