snooc
March 6, 2014, 5:47pm
1
Hello guys!
A friend and I tried to find out why this happens for days now. If I am not running CUDA byte code on my machine as root, I am not able to use the libraries functionallity. Please take a look at the console log I postet below which does exactly show what happens if you command in this exact order on my machine. We did not observe this behavior on my friends machine.
Maybe someone of this forum can help us …
My hardware: archlinux description: Laptop product: W3x0ET (To be filled by O.E.M.) - Pastebin.com
CPU: Intel(R) Core™ i7-3610QM CPU @ 2.30GHz
GPU: GeForce GTX 660M
System:
Linux archlinux 3.13.5-1-ARCH #1 SMP PREEMPT Sun Feb 23 00:25:24 CET 2014 x86_64 GNU/Linux
NVIDIA Driver:
local/bumblebee 3.2.1-3
NVIDIA Optimus support for Linux through VirtualGL
local/cuda 5.5.22-1
NVIDIA's GPU programming toolkit
local/lib32-nvidia-libgl 334.21-1
NVIDIA drivers libraries symlinks (32-bit)
local/lib32-nvidia-utils 334.21-1
NVIDIA drivers utilities (32-bit)
local/libcl 1.1-3
OpenCL library and ICD loader from NVIDIA
local/libvdpau 0.7-1
Nvidia VDPAU library
local/nvidia 334.21-2
NVIDIA drivers for linux
local/nvidia-utils 334.21-1
local/opencl-nvidia 334.21-1
OpenCL implemention for NVIDIA
local/pycuda-headers 2013.1.1-3
Python wrapper for Nvidia CUDA
local/python2-pycuda 2013.1.1-3
snooc
March 6, 2014, 5:48pm
2
Console Log:
[snooc@archlinux mergeSort]$ ./mergeSort
./mergeSort Starting...
CUDA error at ../../common/inc/helper_cuda.h:898 code=38(cudaErrorNoDevice) "cudaGetDeviceCount(&device_count)"
[snooc@archlinux mergeSort]$ sudo modprobe nvidia-uvm
CUDA error at ../../common/inc/helper_cuda.h:898 code=30(cudaErrorUnknown) "cudaGetDeviceCount(&device_count)"
[snooc@archlinux mergeSort]$ lsmod | grep nv
nvidia_uvm 25990 0
nvidia 10736148 1 nvidia_uvm
drm 239102 4 i915,drm_kms_helper,nvidia
i2c_core 24760 7 drm,i915,i2c_i801,drm_kms_helper,i2c_algo_bit,nvidia,videodev
[snooc@archlinux mergeSort]$ sudo ./mergeSort
GPU Device 0: "GeForce GTX 660M" with compute capability 3.0
Allocating and initializing host arrays...
Allocating and initializing CUDA arrays...
Initializing GPU merge sort...
Running GPU merge sort...
Time: 103.632004 ms
Reading back GPU merge sort results...
Inspecting the results...
...inspecting keys array: OK
...inspecting keys and values array: OK
...stability property: stable!
Shutting down...
[snooc@archlinux mergeSort]$ sudo modprobe -r nvidia_uvm
Time: 103.625000 ms
Shutting down...
PS: I had to make a second post because the forum wouldn’t allow me to post this all in one. Don’t ask me… server replied “permission denied”.
I believe on another thread someone mentioned that this issue does not occur with CUDA 6.0 RC, if you wish to use the latest driver.
