CUDA: How to run cuda kernel functions not in SDK? Compilation issues
CUDA: How to run cuda kernel functions not in SDK directory?
I am currently trying to modify the program (already implemented in C++, and running properly on CPU). I am planning to create a separate CUDA kernel function as a different file to run that small portion of the program on GPU.
However, I would like to hear some recommendations from what .h files should I include ? and compilation issues that might arise.
Thank you
I created a separate project in VS 2005 for all my cuda files and applied the following build rule to it:
<?xml version="1.0" encoding="utf-8"?>
<VisualStudioToolFile
	Name="CUDA rules"
	Version="8.00"
	<Rules>
  <CustomBuildRule
  	Name="CUDA compiler"
  	DisplayName="CUDA compiler"
  	CommandLine="$(CUDA_BIN_PATH)\nvcc.exe -ccbin "$(VCInstallDir)bin" [emulation] -c [definitions] -DWIN32 -D_CONSOLE -D_MBCS -Xcompiler /EHsc,/W3,/nologo,/Wp64,[Optimization],/Zi,[RTC],[MT] -I"$(CUDA_INC_PATH)" -I./ -I"$(NVSDKCUDA_ROOT)"/common/inc -o $(ConfigurationName)\$(InputName).obj $(InputName).cu"
  	Outputs="$(ConfigurationName)\$(InputName).obj"
  	FileExtensions="*.cu"
  	ExecutionDescription="$(InputFileName)"
  	<Properties>
   <BooleanProperty
    	Name="emulation"
    	DisplayName="Enable Emulation Mode"
    	Category="Default"
    	Description="Compiles the code to run in emulation mode."
    	Switch="-deviceemu"
    	DefaultValue="false"
    <BooleanProperty
    	Name="fastmath"
    	DisplayName="Use Fast Math"
    	Category="Default"
    	Description="Make use of the fast math library."
    	Switch="-use_fast_math"
        <BooleanProperty
    	Name="RTC"
    	DisplayName="Enable RTC"
    	Category="Default"
    	Description="RTC"
    	Switch="/RTC1"
   <StringProperty
    	Name="optimization"
    	DisplayName="Optimization Level"
    	Description="Sets the optimization level, where level = /Od, /O1, /O2, or /O3."
        Switch="[value]"
   <StringProperty
    	Name="MT"
    	DisplayName="MT usage"
    	Category="Default"
    	Description="/MT or /MTd for debug"
        Switch="[value]"
   <StringProperty
    	Name="definitions"
    	DisplayName="Preprocessor Definitions"
    	Description="Defines a text macro with the given name.    (-D[symbol])"
    	Switch="-D_[value]"
    	Delimited="true"
    	Inheritable="true"
    <StringProperty
    	Name="includes"
    	DisplayName="Include Paths"
    	Description="Sets path for include file. A maximum of 10 -I options is allowed.    (-I [path])"
    	Switch="-I"[value]""
    	Delimited="true"
    	Inheritable="true"
    	DefaultValue="$(CUDA_INC_PATH), $(VCInstallDir)\include, $(VCInstallDir)\PlatformSDK\include"
 	</Properties>
  </CustomBuildRule>
	</Rules>
</VisualStudioToolFile>
AFAIK each “.cu” file should include <cuda_runtime.h> and <cutil.h>.
Functions which are located in “.cu” - files and called from non-CUDA code should be declared as extern “C”.
You don’t strictly need to include <cutil.h>, this includes some common functions used by the NVidia demos for loading textures, doing timings and so on. Useful, but not neccesary. Only cuda_runtime.h and maybe cuda.h you really need.
Isn’t that only the case if you want to use CU or C++ functions from C? From C++ you probably don’t need anything special apart from wrapping your kernel call in a function.
It MUST be
 	CommandLine=""$(CUDA_BIN_PATH)\nvcc.exe" ....
I hate “please path without spaces” folks.
May be. I use kernel wrappers from another libs and it doesnt seems to work without “extern C”. Probably I am doing something wrong.
Thank you. I missed it.
CUDA 1.0 mangles names as C, so you NEED to declare function definitions as extern “C” in the header file so that C++ can call them. CUDA 1.1 now mangles names as c++ by default, even if you aren’t using the c++ compilation mode for .cu files.
MisterAnderson42
Thanks for the explanation.
If you just run on the windows , use the CUDA_VS_Wizard. It is developed by the OpenHeros.
