HI I’m a new cuda learner, i’d like to read a 512*512 image(lena.bmp) and mirror display it ,
this is my code, i can finish compiler it, but i got segmatantion error,
can anyone help me!!
thanks!!!
#include “stdio.h”
#include “stdlib.h”
#include “cuda.h”
int bmp_read(unsigned char *, int , int , char *);
int bmp_write(unsigned char *, int , int , char *);
global void Mirror(unsigned char *, unsigned char *, int , int);
int main() {
unsigned char *ori, *tar;
unsigned char *d_ori,*d_tar;
int xsize = 512;
int ysize = 512;
int n=xsize*ysize*3;
double t_start,t_end;
ori = (unsigned char *)malloc((size_t)xsize * ysize * 3);
tar = (unsigned char *)malloc((size_t)xsize * ysize * 3);
bmp_read(ori, xsize, ysize, "lena.bmp");
cudaMalloc((void**)&d_tar,n*sizeof(char));
cudaMalloc((void**)&d_ori,n*sizeof(char));
cudaMemcpy(d_ori,ori,n*sizeof(char),cudaMemcpyHostToDevice);
cudaMemcpy(d_tar,tar,n*sizeof(char),cudaMemcpyHostToDevice);
t_start=clock();
dim3 dimGrid(32,96);
dim3 dimBlock(16,16);
Mirror<<<dimGrid,dimBlock>>>(d_tar, d_ori, xsize ,ysize);
t_end=clock();
cudaMemcpy(tar,d_tar,n*sizeof(char),cudaMemcpyDeviceToHost);
bmp_write(d_tar, xsize, ysize, "lena_cuda");
cudaFree(d_tar);
cudaFree(d_ori);
printf("run time:%lfs",(double)((t_end-t_start)/CLOCKS_PER_SEC));
int bmp_read(unsigned char *image, int xsize, int ysize, char *filename) {
char fname_bmp[128];
sprintf(fname_bmp, “%s.bmp”, filename);
FILE *fp;
if (!(fp = fopen(fname_bmp, "rb")))
return -1;
unsigned char header[54];
fread(header, sizeof(unsigned char), 54, fp);
fread(image, sizeof(unsigned char), (size_t)(long)xsize * ysize * 3, fp);
fclose(fp);
return 0;
int bmp_write(unsigned char *image, int xsize, int ysize, char *filename) {
unsigned char header[54] = {
0x42, 0x4d, 0, 0, 0, 0, 0, 0, 0, 0,
54, 0, 0, 0, 40, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 24, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0
long file_size = (long)xsize * (long)ysize * 3 + 54;
header[2] = (unsigned char)(file_size &0x000000ff);
header[3] = (file_size >> 8) & 0x000000ff;
header[4] = (file_size >> 16) & 0x000000ff;
header[5] = (file_size >> 24) & 0x000000ff;
long width = xsize;
header[18] = width & 0x000000ff;
header[19] = (width >> 8) &0x000000ff;
header[20] = (width >> 16) &0x000000ff;
header[21] = (width >> 24) &0x000000ff;
long height = ysize;
header[22] = height &0x000000ff;
header[23] = (height >> 8) &0x000000ff;
header[24] = (height >> 16) &0x000000ff;
header[25] = (height >> 24) &0x000000ff;
sprintf(fname_bmp, "%s.bmp", filename);
FILE *fp;
if (!(fp = fopen(fname_bmp, "wb")))
return -1;
fwrite(header, sizeof(unsigned char), 54, fp);
fwrite(image, sizeof(unsigned char), (size_t)(long)xsize * ysize * 3, fp);
fclose(fp);
return 0;
global void Mirror(unsigned char *ori,unsigned char *tar,int xsize,int ysize)
int n=xsizeysize3;
int x=blockIdx.xblockDim.x+threadIdx.x;
int y=blockIdx.yblockDim.y+threadIdx.y;
int index=y*xsize+x;
if(index<=n)
tar[index]=ori[n-index];
