Hi all. First of all i don’t know whether this is the right place to ask this question, kindly tell me if it is not. Currently I tried to compile Abinit 7.8.1 with CUDA enabled. The program can be installed successfully but unfortunately cannot pass the tests provided. The process always stops at “chkinp: Checking input parameters for consistency”
Below is the main errors that appear in the log file:
--- !ERROR
message: |
Checking consistency of input data against itself gave 1 inconsistencies.
src_file: chkinp.F90
src_line: 3003
leave_new : decision taken to exit ...
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 14.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
chkinp : ERROR -
When GPU is in use (use_gpu_cuda=1), ngfft(4:6) must be equal to ngfft(1:3) !
Action: suppress ngfft in input file or change it.
--- !ERROR
message: |
src_line: 3003
If there is anyone who had used Abinit with CUDA before please kindly advise. Any help is appreciated.
