I would like to use my MacBook Pro to learn Pytorch with the use of the GPU. I looked around the web, I couldn’t find exactly what I need for my machine.
Here are the details of my HW and SW. I am trying to use CUDA 8.0, I was not able to use a newer version. thank you for any help.
Hardware
- MacBook Pro Early 2013 15-inch
- Processor: 2.7 GHz Intel Core i7
- Memory: 16 GB 1600 MHz DDR3
- Graphics:
- NVIDIA GeForce GT 650M 1024 MB
- ntel HD Graphics 4000 1536 MB
Software versions
- macOS Sierra Version 10.13.6 (17G6030)
- GPU Driver Version: Nvidia Web Driver - 387.10.10.10.40.127
- CUDA Driver Version:
- cat /usr/local/cuda/version.txt
- CUDA Version 8.0.62
- [cuDNN v5.1 Library for OSX]
- cudnn-8.0-osx-x64-v5.1-tgz) (Jan 20, 2017), for CUDA 8.0
- XCODE Version 9.4.1 (9F2000)
- conda 4.8.5
cc seems fine:
% cc --version
Apple LLVM version 9.1.0 (clang-902.0.39.2)
Target: x86_64-apple-darwin17.7.0
Thread model: posix
InstalledDir: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin
installation of cuddnn:
cd ~/Downloads
tar xzvf cudnn-8.0-osx-x64-v5.1.tar
sudo mv cuda/include/cudnn.h /Developer/NVIDIA/CUDA-8.0/include/
sudo mv cuda/lib/libcudnn* /Developer/NVIDIA/CUDA-8.0/lib
sudo ln -s /Developer/NVIDIA/CUDA-8.0/lib/libcudnn* /usr/local/cuda/lib/
I have added in ~/.bash_profile
export PATH="/Developer/NVIDIA/CUDA-8.0/bin:$PATH"
export DYLD_LIBRARY_PATH="/Developer/NVIDIA/CUDA-8.0/lib:$DYLD_LIBRARY_PATH"
export CUDA_HOME="/usr/local/cuda"
export PATH="/usr/local/cuda/extras/CUPTI/lib:$PATH"
export DYLD_LIBRARY_PATH="/usr/local/cuda/extras/CUPTI/lib:$DYLD_LIBRARY_PATH"
export CMAKE_PREFIX_PATH=“/Users/pytorch/opt/anaconda3:$CMAKE_PREFIX_PATH"
export CUDNN_LIBRARY="/Developer/NVIDIA/CUDA-8.0/lib/libcudnn.5.dylib"
export CUDNN_INCLUDE_DIR="/Developer/NVIDIA/CUDA-8.0/include"
export CUDNN_LIB_DIR="/Developer/NVIDIA/CUDA-8.0/lib"
sanity check on nvcc
% nvcc --version
nvcc: NVIDIA ® Cuda compiler driver
Copyright © 2005-2016 NVIDIA Corporation
Built on Tue_Jan_10_13:22:46_CST_2017
Cuda compilation tools, release 8.0, V8.0.61
I get error if I compile one of one examples:
% cd /usr/local/cuda/samples/1_Utilities/deviceQuery
% sudo make
/Developer/NVIDIA/CUDA-8.0/bin/nvcc -ccbin clang++ -I…/…/common/inc -m64 -Xcompiler -arch -Xcompiler x86_64 -gencode arch=compute_20,code=sm_20 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_60,code=compute_60 -o deviceQuery.o -c deviceQuery.cpp
nvcc warning : The ‘compute_20’, ‘sm_20’, and ‘sm_21’ architectures are deprecated, and may be removed in a future release (Use -Wno-deprecated-gpu-targets to suppress warning).
nvcc fatal : The version (‘90100’) of the host compiler (‘Apple clang’) is not supported
make: *** [deviceQuery.o] Error 1
I am not sure about how to install pytorch with conda, I tried:
conda install pytorch torchvision cudatoolkit=8.0 -c pytorch
but I get errors:
PackagesNotFoundError: The following packages are not available from current channels:
- cudatoolkit=8.0
when I try in Python:
import torch
print(torch.version)
1.6.0torch.cuda.is_available()
False
