now it is strange problem
currently doing 6 encodings quadro m2000. No problem with up to 6 streams.
If I open one more stream, cuda will not allow it. give the following error. There is no problem up to 6 streams.
Please help m
| NVIDIA-SMI 390.48 Driver Version: 390.48 |
| 0 NVS 315 Off | 00000000:73:00.0 N/A | N/A |
| 30% 42C P8 N/A / N/A | 870MiB / 963MiB | N/A Default |
| 1 Quadro M2000 Off | 00000000:D5:00.0 Off | N/A |
| 56% 43C P0 29W / 75W | 1058MiB / 4043MiB | 5% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 Not Supported |
| 1 3274 C /root/bin/ffmpeg 167MiB |
| 1 3276 C /root/bin/ffmpeg 167MiB |
| 1 3802 C /root/bin/ffmpeg 167MiB |
| 1 3804 C /root/bin/ffmpeg 167MiB |
| 1 3811 C /root/bin/ffmpeg 167MiB |
| 1 4043 C /root/bin/ffmpeg 167MiB |
root@ubuntu:~# nvidia-smi dmon
gpu pwr temp sm mem enc dec mclk pclk
Idx W C % % % % MHz MHz
1 30 45 6 11 36 31 3304 1227
1 30 45 5 10 35 31 3304 1227
1 31 45 5 10 36 31 3304 1227
1 28 45 6 10 35 31 3304 1227
1 29 45 4 8 36 31 3304 1227
1 33 45 7 14 37 32 3304 1227
1 31 45 9 17 38 33 3304 1227
1 32 45 8 15 37 33 3304 1227
1 28 45 6 12 37 32 3304 1227
1 28 45 6 12 36 32 3304 1227
1 32 45 6 11 36 32 3304 1227
1 30 45 6 12 36 32 3304 1227
1 32 45 6 11 37 32 3304 1227
Duration: N/A, start: 45158.724533, bitrate: N/A
Program 1
Metadata:
service_name : 24 HD
service_provider: TURK MEDYA
Stream #0:0[0x13bf]: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, top first), 1920x1080 [SAR 1:1 DAR 16:9], 25 fps, 50 tbr, 90k tbn, 50 tbc
Stream #0:10x1423: Audio: mp2 ([4][0][0][0] / 0x0004), 48000 Hz, stereo, s16p, 256 kb/s
[AVHWDeviceContext @ 0x437f940] Could not initialize the CUDA driver API
[h264_cuvid @ 0x4061380] Error creating a CUDA device
cuvid hwaccel requested for input stream #0:0, but cannot be initialized.
[h264_cuvid @ 0x4061380] ff_get_format failed: -1
Stream mapping:
Stream #0:0 → #0:0 (h264 (h264_cuvid) → h264 (h264_nvenc))
Stream #0:1 → #0:1 (mp2 (native) → aac (libfdk_aac))
Error while opening decoder for input stream #0:0 : Operation not permitted
