Hi all,
I am trying to run a simple script to analyze attention scores of Llama-2-7b-32k model on Jetstream2 cluster. I was able to run other scripts on the same cluster but I suddenly started seeing the following error when importing a model from transformers library from huggingface
File "/home/exouser/Squeezed-Attention/offline_clustering.py", line 8, in <module>
from utils.model_parse import (
File "/home/exouser/Squeezed-Attention/utils/model_parse.py", line 1, in <module>
from transformers import AutoModelForCausalLM, LlamaForCausalLM, OPTForCausalLM
File "<frozen importlib._bootstrap>", line 1055, in _handle_fromlist
File "/home/exouser/Squeezed-Attention/transformers/src/transformers/utils/import_utils.py", line 1500, in __getattr__
value = getattr(module, name)
File "/home/exouser/Squeezed-Attention/transformers/src/transformers/utils/import_utils.py", line 1499, in __getattr__
module = self._get_module(self._class_to_module[name])
File "/home/exouser/Squeezed-Attention/transformers/src/transformers/utils/import_utils.py", line 1511, in _get_module
raise RuntimeError(
RuntimeError: Failed to import transformers.models.llama.modeling_llama because of the following error (look up to see its traceback):
cudaErrorInitializationError: initialization error
my current set up is below:
| NVIDIA-SMI 550.120 Driver Version: 550.120 CUDA Version: 12.4 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA A100-SXM4-40GB Off | 00000000:04:00.0 Off | 0 |
| N/A 25C P0 52W / 400W | 1MiB / 40960MiB | 0% Default |
| | | Disabled |
Copyright (c) 2005-2024 NVIDIA Corporation
Built on Thu_Jun__6_02:18:23_PDT_2024
Cuda compilation tools, release 12.5, V12.5.82
Build cuda_12.5.r12.5/compiler.34385749_0
I am quite to new in this area but if anyone has any ideas on where the root cause is please let me know.
