I am using the magma library and I found that magma_init() takes a lot of time…this function is wrapper for cudaGetDeviceCount(), so cudaGetDeviceCount() takes, surprisingly too much time. Is there any help where the problem might be? I am using K40
Here is the link to the thread in magma forum I made
How much time, exactly? Is this a system with multiple GPUs or large system memory? A Windows or a Linux system? If the latter: Is the CUDA driver in persistence mode? Other than calling cudaGetDeviceCount(), what does magma_init() do?
Up to 2 seconds. Its one K40c on a Linux system.Persistence mode is disabled.
Actually the first cuda call was taking too much time. Here are some numbers in various servers
If you only intend to use a single GPU, then use the CUDA_VISIBLE_DEVICES environment variable to restrict your CUDA runtime footprint to that GPU only:
That is about all I know of that you can reasonably do to reduce init time. Init time may vary based on your exact program, CUDA version, driver version, OS (e.g. linux or windows), exact GPU being used, size of system memory, number of GPUs in the system (although see above) and probably other factors.
In some cases, enabling persistence mode can make a substantial difference in init time.
Once you have addressed the items listed by txbob, I think you will find that CUDA initialization time is largely a function of the amount of system memory in each server, because all memory (attached to GPus and CPUs) in the machine needs to be mapped into a single address space at CUDA startup. Because this mapping involves mostly single-threaded OS calls, you may find (other parameters being equal) that the server with the highest single-thread performance initializes in the shortest time. You may also find that higher system memory throughput reduces the initialization time.
