I’m new to CUDA. I installed Visual C++ 2010 Express, then installed CUDA 5.0. I can run the binary 5.0 samples, and can compile the provided 5.0 sample solutions. When I try to compile any of the examples in “CUDA by example” I get a link error.
For example:
nvcc -m32 chapter03\hello_world.cu
hello_world.cu
tmpxft_0000d2d8_00000000-5_hello_world.cudafe1.gpu
tmpxft_0000d2d8_00000000-10_hello_world.cudafe2.gpu
hello_world.cu
tmpxft_0000d2d8_00000000-5_hello_world.cudafe1.cpp
tmpxft_0000d2d8_00000000-15_hello_world.ii
LINK : fatal error LNK1104: cannot open file ‘a.exe’
I do not exactly know what’s going on there but if you haven’t run the command prompt as administrator try it again in this manner.
run command prompt as administrator and check it again.
That worked, thanks. If I open the VS command window as administrator everything’s fine. Does that mean I did something wrong in the installation, or do folks normally have to run this as administrator?
