I was just wondering if there is currently, if it’s planned, or if there is any general appetite for Cuda to support the Intel compiler?
Matt
Matt
It is not supported currently. I don’t remember reading about plans to support it.
You can compile your cuda codes with nvcc, put them in a static library, then use the Intel compiler to link everything.
(If you are using the Intel Fortran compiler, make sure that the C function names have underscores appended to the
names called in Fortran.)
