Hi
I’m having an issue getting interop capabilities running. I can successfully run on the GPU without Interop, however as soon as I attempt to activate the Interop the CudaContextManager context becomes invalid.
I am on Visual Studio 2012 using OpenGL as my render system through Ogre 3D rendering engine on x64. I am currently linked to the debug versions of the libraries, though I was on CHECKED originally:
PhysX3CommonDEBUG_x64.lib
PhysX3DEBUG_x64.lib
PhysX3ExtensionsDEBUG.lib
PxTaskDEBUG.lib
PhysXProfileSDKDEBUG.lib
PhysXVisualDebuggerSDKDEBUG.lib
In case I am missing a necessary lib, there’s what I have linked so far.
My current code:
if(initializeCuda)
if(!descriptor.gpuDispatcher)
physx::PxCudaContextManagerDesc cudaContextManagerDesc;
cudaContextManagerDesc.interopMode = physx::PxCudaInteropMode::OGL_INTEROP;
HGLRC hg = wglGetCurrentContext();
cudaContextManagerDesc.graphicsDevice = (void*)&hg;///I know I don't need to do it this way, just part of debugging
cudaContextManager = physx::PxCreateCudaContextManager(PxGetFoundation(), cudaContextManagerDesc, PxGetPhysics().getProfileZoneManager());
std::string result;
if(cudaContextManager->contextIsValid())
result = "Context Valid";
else
result = "Not Valid";
printf(result.c_str());
if(cudaContextManager)
descriptor.gpuDispatcher = cudaContextManager->getGpuDispatcher();
I can confirm that I am getting a valid HGLRC, so if anyone has any ideas, I would greatly appreciate the assistance. The part where it fails is at ContextIsValid(). And as I said above, if not using Interop, everything runs smoothly. So it would appear I have a correct setup.
I’m hoping someone can help me with this as I have spent a couple days on this now.
Thank you
