Cuda Kernel CU_EGL_COLOR_FORMAT_Y10V10U10_420_SEMIPLANAR
I need some help with Cuda Kernels when eglFrame.eglColorFormat == CU_EGL_COLOR_FORMAT_Y10V10U10_420_SEMIPLANAR
I am getting unexpected results.
To help explain, I am attaching screenshots comparing results when I use P010_10LE frame vs. NV12 frame.
I am using the following functions to get yElement[0], uvElement[0], and uvElement[1]:
device char *
get_pixel_uv(char *pDevPtr, const int pitch, const int row, const int col, const int width, const int height) {
if (col >= 0 && row >= 0 && col < width && row < height) {
return pDevPtr + row * pitch + col * 2;
} else {
return NULL;
device char *
get_pixel_y(char *pDevPtr, const int pitch, const int row, const int col, const int width, const int height) {
return pDevPtr + row * pitch + col;
} else {
return NULL;
global void addLabelsKernel(char* pDevYPtr, char* pDevUVPtr, const int pitch, const int width, const int height)
int row = blockIdx.y * blockDim.y + threadIdx.y;
int col = blockIdx.x * blockDim.x + threadIdx.x;
char * yElement = get_pixel_y(pDevYPtr, pitch, row, col, width, height);
if (NULL == yElement) {
return;
char * uvElement = get_pixel_uv(pDevUVPtr, pitch, row/2, col/2, width, height);
if (NULL == uvElement) {
return;
/* THESE ARE THE THREE TESTS */
yElement[0] -= 800.0f;
uvElement[0] = 0.0f;
uvElement[1] = 0.0f;
return;
extern ā€œCā€ int addLabels(CUdeviceptr pDevYPtr, CUdeviceptr pDevUVPtr, int pitch, int width, int height)
dim3 threadsPerBlock(BOX_W, BOX_H);
dim3 blocks(((width + BOX_W-1) / BOX_W), (height + BOX_H-1) / BOX_H);
addLabelsKernel<<<blocks,threadsPerBlock>>>((char*)pDevYPtr, (char*)pDevUVPtr, pitch, width, height);
return 0;
The three tests I run simply change values of each yElement[0], uvElement[0], and uvElement[1] and compare using formats NV12 and P010_10LE
NV12, yElement[0] -=800
P010_10LE,yElement[0] -=800
NV12,uvElement[0]=0
P010_10LE,uvElement[0]=0
NV12,uvElement[1]=0
P010_10LE,uvElement[1]=0
and lastly, NV12 uvElement[0]=0 and uvElement[1]=0
Can somebody help me understand what is going on?
We need to check with our internal team and update more info with you.
The data layout is like
NV12: two planes. One Y plane and one UV interleaved plane. Each pixel is 1 byte, 8-bit valid data.
For one 1920x1080 frame, Y plane is 1920x1080 bytes, and UV plane is 1920x1080x0.5 bytes
P010_10LE: two planes. One Y plane and one UV interleaved plane. Each pixel is 2 bytes, 10-bit valid data and 6-bit padding.
For one 1920x1080 frame, Y plane is 1920x1080x2 bytes, and UV plane is 1920x1080x2x0.5 bytes
