CUDA Kernel functions don't work with Multimedia API
I am trying to create a CUDA application that applies an processing algorithm to each video frame decoded from a video file (H264).
I downloaded the multimedia API from the Jetson Download Center (both releases 32.2.1 and 28.3.1) and compiled the sample 02 (video decoder + cuda).
The sample 02 is supposed to draw a square (32 x 32) on top of the video decoded, however, I can see no square at all. Video displays fine.
I tried in the the Nano and in the Xavier. Both behave the same way.
I tried to change the square color/size but never was able to see any square. and changed the kernel call in different ways to try to display something, always unsuccessful
However, a call to a CudaMemset applies the color to the screen fine. The problem appears to be only when kernel calls happen
from tegra_multimedia_api/samples/common/algorithm/cuda/NvCudaProc.cpp
  * Performs CUDA Operations on egl image.
  * @param image : EGL image
static void
Handle_EGLImage(EGLImageKHR image)
    CUresult status;
    CUeglFrame eglFrame;
    CUgraphicsResource pResource = NULL;
    cudaFree(0);
    status = cuGraphicsEGLRegisterImage(&pResource, image,
                CU_GRAPHICS_MAP_RESOURCE_FLAGS_NONE);
    if (status != CUDA_SUCCESS)
        printf("cuGraphicsEGLRegisterImage failed: %d, cuda process stop\n",
                        status);
        return;
    status = cuGraphicsResourceGetMappedEglFrame(&eglFrame, pResource, 0, 0);
        printf("cuGraphicsSubResourceGetMappedArray failed\n");
    status = cuCtxSynchronize();
        printf("cuCtxSynchronize failed\n");
    if (eglFrame.frameType == CU_EGL_FRAME_TYPE_PITCH)
        //Rect label in plan Y, you can replace this with any cuda algorithms.
        //addLabels((CUdeviceptr) eglFrame.frame.pPitch[0], eglFrame.pitch); //does not display any square or anything
       <b> cudaMemset((void *)eglFrame.frame.pPitch[0], 120, eglFrame.pitch)</b> //displays a gray line
        printf("cuCtxSynchronize failed after memcpy\n");
    status = cuGraphicsUnregisterResource(pResource);
        printf("cuGraphicsEGLUnRegisterResource failed: %d\n", status);
So, did anybody ever get kernel calls to change a buffer using this Multimedia API?
Please install whole package through sdkmanager and then run
$ export DISPLAY=:1
$ /usr/src/tegra_multimedia_api/samples/02_video_dec_cuda/video_dec_cuda /usr/src/tegra_multimedia_api/data/Video/sample_outdoor_car_1080p_10fps.h264 H264
Hi DaneLLL,
I tried reinstalling everything again and running the commands above, and the behaviour is the same. I see no squares at all.
I used JetPack 4.2.2 and the release 32.2 (flashed new OS image as well).
The video runs but I see no squares. I tried also with a Jetson Nano and no squares in the Nano as well.
I attached a screenshot of the video running.
Please try
$ gst-launch-1.0 videotestsrc num-buffers=400 ! nvvidconv ! nvv4l2h264enc ! h264parse ! video/x-h264,stream-format=byte-stream ! filesink location=a.h264
$ /usr/src/tegra_multimedia_api/samples/02_video_dec_cuda/video_dec_cuda a.h264 H264
sample_outdoor_car_1080p_10fps.h264 is pretty dark at top-left corner and it is not obvious.
Hi DaneLLL, It’s clear now, it was my mistake. It works fine
The square is drawn exactly at the dark spot.
