I am testing the performance of L1 cache bypass and L1 cache enabled on A40 GPU. I am using a random pointer chasing to achieve that. Ideally, my expectation is when working set size no longer fits to L1, L1 cache bypass should provide lower memory access latency because the system avoids overhead of checking L1 cache, which anyway will lead to a miss. But the experiment does not show that performance. Can anyone share some insights?
Attach my script for doing random pointer chasing.
#include <algorithm>
#include <chrono>
#include <cstdlib>
#include <cuda_runtime.h>
#include <iostream>
#include <random>
#include <vector>
#define N 1000000
__global__ void chase(int *data, int size) {
int d = blockIdx.x * blockDim.x + threadIdx.x;
for (int i = 0; i < N; i++) {
for (int k = 0; k < 128; k++) {
d = data[d];
data[0] = d;
/* simple class for a pseudo-random generator producing
uniformely distributed integers */
class UniformIntDistribution {
public:
UniformIntDistribution() : engine(std::random_device()()) {}
/* return number in the range of [0..upper_limit) */
unsigned int draw(unsigned int upper_limit) {
return std::uniform_int_distribution<unsigned int>(0,
upper_limit - 1)(engine);
private:
std::mt19937 engine;
/* create a cyclic pointer chain that covers all words
in a memory section of the given size in a randomized order */
void create_random_chain(int **indices, int len) {
UniformIntDistribution uniform;
// shuffle indices
for (int i = 0; i < len; ++i) {
(*indices)[i] = i;
for (int i = 0; i < len - 1; ++i) {
int j = i + uniform.draw(len - i);
if (i != j) {
std::swap((*indices)[i], (*indices)[j]);
int main(int argc, char **argv) {
if (argc < 2) {
std::cout << "./main [working set size]" << std::endl;
exit(1);
int working_set_num_size = std::stoi(argv[1]);
int working_set_num = working_set_num_size / sizeof(int);
int *data = new int[working_set_num];
int **data_p = &data;
create_random_chain(data_p, working_set_num);
int *d_data;
cudaMalloc(&d_data, working_set_num_size);
cudaMemcpy(d_data, data, working_set_num_size, cudaMemcpyHostToDevice);
std::chrono::steady_clock::time_point begin = std::chrono::steady_clock::now();
chase<<<1, 1>>>(d_data, working_set_num);
cudaDeviceSynchronize();
std::chrono::steady_clock::time_point end = std::chrono::steady_clock::now();
std::cout << std::chrono::duration_cast<std::chrono::microseconds>(end - begin).count() << std::endl;
Here is my experimental results for latency of each memory access under different setup.
