I am using Nvidia VM on Azure with Ubuntu 20.04
I already had nvidia and cuda installed but hile running my program it still showed libraries not found
nvidia-smi
| NVIDIA-SMI 470.103.01 Driver Version: 470.103.01 CUDA Version: 11.4 |
| | | MIG M. |
| 0 Tesla T4 Off | 00000001:00:00.0 Off | Off |
| N/A 32C P0 25W / 70W | 0MiB / 16127MiB | 6% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
This is the error I see for multiple cuda libraries:
Could not load dynamic library 'libnvinfer.so.6'; dlerror: libnvinfer.so.6: cannot open shared object file: No such file or directory
2022-05-02 05:33:53.131224: W tensorflow/stream_executor/platform/default/dso_loader.cc:55] Could not load dynamic library 'libnvinfer_plugin.so.6'; dlerror: libnvinfer_plugin.so.6: cannot open shared object file: No such file or directory
2022-05-02 05:33:53.131235: W tensorflow/compiler/tf2tensorrt/utils/py_utils.cc:30] Cannot dlopen some TensorRT libraries. If you would like to use Nvidia GPU with TensorRT, please make sure the missing libraries mentioned above are installed properly.
Could not load dynamic library 'libcudnn.so.7'; dlerror: libcudnn.so.7: cannot open shared object file: No such file or directory
2022-05-02 05:33:55.738515: W tensorflow/core/common_runtime/gpu/gpu_device.cc:1592] Cannot dlopen some GPU libraries.
I am not sure if this error is because of GPG key error rotation or something else, since i tried to install driver separately as well but it kept giving error of not locating drivers.
I also tried:
sudo apt-get -y install cuda
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
cuda : Depends: cuda-11-6 (>= 11.6.2) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
I am using tensorflow-gpu-2.1.3 as thats the requirement for my program.
Please help.
@kmittman
