I am building Visual Studio 2017 project with CMake 3.13.1. I am using CUDA 9.2.
When separable compilation is activated, function (inside FindCUDA.cmake)
function(CUDA_LINK_SEPARABLE_COMPILATION_OBJECTS
sets up host flags ( ${flags} ) that are passed to NVCC when performing device link (-dlink) of relocatable device code (line 1911).
Build configuration specific flags are setup in the following fashion (line 1875):
foreach(f ${important_host_flags})
list(APPEND flags $<$<CONFIG:${config}>:-Xcompiler> $<$<CONFIG:${config}>:${f}>)
endforeach()
The flags are then passed on to nvcc, that is invoked in a custom build step like so (line 1906):
add_custom_command(
OUTPUT ${output_file}
DEPENDS ${object_files}
COMMAND ${CUDA_NVCC_EXECUTABLE} ${nvcc_flags} -dlink ${object_files} -o ${output_file}
${flags}
COMMENT "Building NVCC intermediate link file ${output_file_relative_path}"
${_verbatim}
The following snippet from the above code invokes nvcc with the aforementioned flags ( ${flags} ):
COMMAND ${CUDA_NVCC_EXECUTABLE} ${nvcc_flags} -dlink ${object_files} -o ${output_file} ${flags}
As far as I am concerned, the idea was for ${flags} to expand into one particular flag depending on the built configuration (given that flags are populated with generator expressions), i.e., if we are building Debug:
COMMAND ${CUDA_NVCC_EXECUTABLE} ${nvcc_flags} -dlink ${object_files} -o ${output_file} -Xcompiler /MDd
However, what happens is that generator expressions in ${flags} that do not comply with the currently built configuration are simply set to an empty string. So if we are building Debug configuration, we get the following:
Which results in
nvcc fatal : Don't know what to do with ''
Removing the loop that populates the ${flags} and manually setting flags to, say,
-Xcompiler /MDd
fixes the problem, lets the project build and the code is successfully run.
I was wondering if I am missing something in the script, or is it a bug? I apologize in advance if I overlooked something fundamental.
