Cuda-llm-weight-share - LLM weight share for cuda across multiple processes
I wrote a simple weight-sharing library that allows multiple independent processes to share a single copy of a large machine learning model’s weights in CUDA VRAM.
I tested it with llama.cpp. As a result, I can run independent llama.cpp processes with different settings, such as context size, prompt cache size, and concurrency without LLM weight duplication.
How to use:
Find weight size in VRAM that you want to share
`LD_PRELOAD=./cuda-llm-weight-share.so /home/pont/git/llama.cpp/build/bin/llama-server  -hf unsloth/Qwen3.6-35B-A3B-MTP-GGUF:UD-Q6_K_XL --host 0.0.0.0 --port 8000 --no-mmap  -cram 0 -np 1 --ctx-checkpoints 0 -lv 1 `
`[VRAM_HOOK] cudaMalloc: Allocated 860.98 MB (902804096 bytes) at 0xef6e40000000 `
`[VRAM_HOOK] cudaMalloc: Allocated 248.10 MB (260149504 bytes) at 0x32ee00000 `
`[VRAM_HOOK] cudaMalloc: Allocated 62.81 MB (65863680 bytes) at 0xef6e76200000 `
`[VRAM_HOOK] cudaMalloc: Allocated 30575.16 MB (32060375552 bytes) at 0xef66c0000000 `
`[VRAM_HOOK] cudaMalloc: Allocated 5120.00 MB (5368709120 bytes) at 0xef6580000000 `
`[VRAM_HOOK] cudaMalloc: Allocated 62.81 MB (65863680 bytes) at 0xef6e37200000 `
`[VRAM_HOOK] cudaMalloc: Allocated 324.02 MB (339755264 bytes) at 0xef6e60400000 `
`[VRAM_HOOK] cudaMalloc: Allocated 860.98 MB (902804096 bytes) at 0xef6520000000 `
`[VRAM_HOOK] cudaMalloc: Allocated 248.10 MB (260149504 bytes) at 0xef6500000000`
Run first process(master)
`MODEL_SIZE=32060375552  LD_PRELOAD=./cuda-llm-weight-share.so /home/pont/git/llama.cpp/build/bin/llama-server  -hf unsloth/Qwen3.6-35B-A3B-MTP-GGUF:UD-Q6_K_XL --host 0.0.0.0 --port 8000 --no-mmap  -cram 0 -np 1 --ctx-checkpoints 0 -lv 1 `
`[VRAM_HOOK] cudaMalloc: Allocated 860.98 MB (902804096 bytes) at 0xfced00000000 `
`[VRAM_HOOK] cudaMalloc: Allocated 62.81 MB (65863680 bytes) at 0xfced36200000 `
`[VRAM_HOOK] =================================================== `
`[VRAM_HOOK] Target weights size intercepted: 30575.16 MB `
`[VRAM_HOOK] WARNING: Stale IPC found. Master (PID 60765) is DEAD. `
`[VRAM_HOOK] Taking over and becoming the new MASTER... `
`[VRAM_HOOK] No active MASTER found. Assuming MASTER role. `
`[VRAM_HOOK] MASTER: Memory allocated at 0xfce580000000 and published. `
`[VRAM_HOOK] cudaMalloc: Allocated 5120.00 MB (5368709120 bytes) at 0xfce440000000 `
`[VRAM_HOOK] cudaMalloc: Allocated 62.81 MB (65863680 bytes) at 0xfcecf7200000 `
`[VRAM_HOOK] cudaMalloc: Allocated 324.02 MB (339755264 bytes) at 0xfced20400000 `
`[VRAM_HOOK] cudaMalloc: Allocated 860.98 MB (902804096 bytes) at 0xfce3e0000000`
Run second process
`MODEL_SIZE=32060375552 LD_PRELOAD=./cuda-llm-weight-share.so /home/pont/git/llama.cpp/build/bin/llama-server  -hf unsloth/Qwen3.6-35B-A3B-MTP-GGUF:UD-Q6_K_XL --host 0.0.0.0 --port 8001 --no-mmap  -cram 0 -np 1 --ctx-checkpoints 0 -lv 1 `
`[VRAM_HOOK] cudaMalloc: Allocated 860.98 MB (902804096 bytes) at 0xe37720000000 `
`[VRAM_HOOK] cudaMalloc: Allocated 62.81 MB (65863680 bytes) at 0xe37756200000 `
`[VRAM_HOOK] Found active MASTER (PID 61493). Assuming WORKER role. `
`[VRAM_HOOK] WORKER: IPC handle mapped successfully at 0xe36fa0000000. ZERO VRAM spent! `
`[VRAM_HOOK] cudaMalloc: Allocated 5120.00 MB (5368709120 bytes) at 0xe36e60000000 `
`[VRAM_HOOK] cudaMalloc: Allocated 62.81 MB (65863680 bytes) at 0xe37717200000 `
`[VRAM_HOOK] cudaMalloc: Allocated 324.02 MB (339755264 bytes) at 0xe37740400000 `
`[VRAM_HOOK] cudaMalloc: Allocated 860.98 MB (902804096 bytes) at 0xe36e20000000 `
`[VRAM_HOOK] cudaMalloc: Allocated 248.10 MB (260149504 bytes) at 0xe36e00000000`
Result
|    0   N/A  N/A           60765    C+G   ...ma.cpp/build/bin/llama-server      37392MiB |
|    0   N/A  N/A           60829    C+G   ...ma.cpp/build/bin/llama-server       6816MiB |
