Hi all,
I have my cuda program in which there are several structure variables allocated. Specifically using the following code for printing the address of each pointer of all the structures of my program allocated on the GPU I have:
[i]cudaMalloc((void**)&mat, size_mat);
cudaError_t error=cudaGetLastError();
if(error != cudaSuccess) {
printf("cudaMalloc: %s\n",cudaGetErrorString(error));
exit(EXIT_FAILURE);
}[/i]
printf(“mat: 0x%X\n”, mat);
ADDRESSING RESULTS:
[b]mat: 0x3AB0000
coordinates: 0x3AC0000
inertiaDev: 0x1000800
errorcodeDev: 0x3B00000
neigh_list: 0x3B10000
neighEl: 0x1000900
potVet: 0x3C10000
sysVirDev: 0x3C20000
coordDev: 0x3C30000
eDev: 0x3C40000
typeDev: 0x1001700
massDev: 0x1002500
interactionTypeDev1: 0x3C50000
sigDev: 0x1002600
epsDev: 0x1002800
productElectroMomentsDev: 0x1002A00[/b]
I have performed the prints in order. It seems as if the program uses 2 different regions of memory (one region 0x3****** and the other 0x1******) and allocates memory in one of these two regions.
Since the memory is allocated in a synchronous way, why doesn’t the program first allocate structures in one region of the GPU and then in the other, but instead it allocates memory quite alternating the two regions?
Thenk you in advance for your answers!!
