Calling the function curandGenerateUniform from the cuRand library fails with the error CURAND_STATUS_LAUNCH_FAILURE only when running the compiled code from the command line with cuda-memcheck
The problem can be generated with a standard example from https://docs.nvidia.com/cuda/curand/host-api-overview.html#host-api-example. (see report below).
I could generate the problem on 2 PCs:
- windows 7 with CUDA SDK v9.0
- windows 10 with CUDA SDK v9.1
Any ideas?
========= CUDA-MEMCHECK
Error at c:/Users/alkamu1/documents/visual studio 2017/Projects/curandTest/curandTest/kernel.cu:39
========= Program hit cudaErrorLaunchFailure (error 4) due to "unspecified launch failure" on CUDA API call to cudaFree.
========= Saved host backtrace up to driver entry point at error
========= Host Frame:C:\Windows\system32\nvcuda.dll (cuTexRefSetAddress + 0x2cae4e) [0x2d849b]
========= Host Frame:C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\bin\curand64_91.dll (curandGeneratePoissonMethod + 0x83f2) [0x3ee92]
========= Host Frame:C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\bin\curand64_91.dll (curandGenerateSeeds + 0x28f) [0x2172f]
========= Host Frame:C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\bin\curand64_91.dll (curandGenerateSeeds + 0x3b01) [0x24fa1]
========= Host Frame:C:\Users\alkamu1\Documents\Visual Studio 2017\Projects\curandTest\x64\Debug\curandTest.exe (main + 0x111) [0x1831]
========= Host Frame:C:\Users\alkamu1\Documents\Visual Studio 2017\Projects\curandTest\x64\Debug\curandTest.exe (invoke_main + 0x34) [0x3f24]
========= Host Frame:C:\Users\alkamu1\Documents\Visual Studio 2017\Projects\curandTest\x64\Debug\curandTest.exe (__scrt_common_main_seh + 0x127) [0x3de7]
========= Host Frame:C:\Users\alkamu1\Documents\Visual Studio 2017\Projects\curandTest\x64\Debug\curandTest.exe (__scrt_common_main + 0xe) [0x3cae]
========= Host Frame:C:\Users\alkamu1\Documents\Visual Studio 2017\Projects\curandTest\x64\Debug\curandTest.exe (mainCRTStartup + 0x9) [0x3f49]
========= Host Frame:C:\Windows\System32\KERNEL32.DLL (BaseThreadInitThunk + 0x14) [0x12784]
========= Host Frame:C:\Windows\SYSTEM32\ntdll.dll (RtlUserThreadStart + 0x21) [0x70d51]
========= Program hit cudaErrorLaunchFailure (error 4) due to "unspecified launch failure" on CUDA API call to cudaThreadSynchronize.
========= Host Frame:C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\bin\curand64_91.dll (curandGeneratePoissonMethod + 0x7c3a) [0x3e6da]
========= Host Frame:C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\bin\curand64_91.dll (curandGenerateSeeds + 0x4b8) [0x21958]
========= Program hit cudaErrorLaunchFailure (error 4) due to "unspecified launch failure" on CUDA API call to cudaGetLastError.
========= Host Frame:C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\bin\curand64_91.dll (curandGeneratePoissonMethod + 0x7d67) [0x3e807]
========= Host Frame:C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\bin\curand64_91.dll (curandGenerateSeeds + 0x4bd) [0x2195d]
========= ERROR SUMMARY: 3 errors
