Cuda-memcheck on Linux 64-bit?
I’m having trouble with the 3.0 beta using cuda-memcheck on Linux 64-bit, Fedora Core 12. It seems only a 32-bit version was provided (I found another downloadable archive at http://developer.download.nvidia.com/compu…_linux64.tar.gz which doesn’t seem to help–it’s not in gz format, by the way, just .tar). I had some expected problems and had to “yum install ld-linux.so.2” and “yum install libstdc++.so.6”, and now cuda-memcheck runs…
[vputz@gyges test]$ cuda-memcheck
usage: cuda-memcheck [options] [your-program] [your-program-options]
…but is useless:
[vputz@gyges test]$ cuda-memcheck main
========= CUDA-MEMCHECK
========= Error: Could not run main
========= Internal Error
Any suggestions? Has anyone been able to use cuda-memcheck on 64-bit Linux?
I haven’t tried the standalone version, but the same features should be available in cuda-gdb via
set cuda memcheck
I am not a fedora user, so I don’t know whether this is a distro specific thing or not.
You’re a champion, avidday. Unfortunately cuda-gdb is segfaulting whenever I specify a breakpoint, and results in odd behaviour sometimes, but this is at least a step.
