I am following the 04_video_dec_trt examples for converting data from mipi camera (libargus) to float array for inference. I am getting the cuda illegal address access error while executing the convertEglFrameIntToFloat
function from NvCudaProc.cpp
file.
Buffer creation:
void createNvBufferForTransform(const Size2D<uint32_t> size, int nBuffers,
ImagingContext *ctxt)
NvBufSurf::NvCommonAllocateParams aParams = {0};
aParams.colorFormat = NvBufSurfaceColorFormat::NVBUF_COLOR_FORMAT_RGBA;
aParams.height = size.height();
aParams.width = size.width();
aParams.layout = NvBufSurfaceLayout::NVBUF_LAYOUT_PITCH;
aParams.memtag = NvBufSurfaceTag::NvBufSurfaceTag_VIDEO_CONVERT;
aParams.memType = NvBufSurfaceMemType::NVBUF_MEM_SURFACE_ARRAY;
ctxt->dstDmaFd = new int[nBuffers];
ctxt->eglFramePtr = new CUeglFrame[nBuffers];
ctxt->pResource = new CUgraphicsResource[nBuffers];
ctxt->eglImagePtr = new EGLImageKHR[nBuffers];
CUresult status;
for (size_t i = 0; i < nBuffers; i++){
NvBufSurf::NvAllocate(&aParams, 1, ctxt->dstDmaFd + i);
NvBufSurface *bufSurf;
int ret = NvBufSurfaceFromFd(*(ctxt->dstDmaFd + i), (void**)&bufSurf);
if (ret < 0){
std::cout << "Surf from fd failed" << std::endl;
continue;
if (bufSurf->surfaceList[0].mappedAddr.eglImage == NULL)
if (NvBufSurfaceMapEglImage(bufSurf, 0) != 0)
std::cout << "Mapping EGL frame failed" << std::endl;
continue;
ctxt->eglImagePtr[i] = (EGLImageKHR*)bufSurf->surfaceList[0].mappedAddr.eglImage;
if (ctxt->eglImagePtr[i] == NULL)
std::cout << "Mapping EGL frame failed again" << std::endl;
continue;
ctxt->pResource[i] = NULL;
cudaFree(0);
status = cuGraphicsEGLRegisterImage(&(ctxt->pResource[i]), ctxt->eglImagePtr[i],
CU_GRAPHICS_MAP_RESOURCE_FLAGS_NONE);
if (status != CUDA_SUCCESS)
printf("cuGraphicsEGLRegisterImage failed: %d, cuda process stop\n",
status);
return;
CUresult cuRes = cuCtxSynchronize();
if(cuRes != CUDA_SUCCESS){
cout << "Cuda sync failed" << endl;
break;
status = cuGraphicsResourceGetMappedEglFrame(&ctxt->eglFramePtr[i], ctxt->pResource[i], 0, 0);
printf("cuGraphicsSubResourceGetMappedArray failed\n");
ctxt->dmaEglMap.insert(pair<int, CUeglFrame*>(*(ctxt->dstDmaFd + i), &ctxt->eglFramePtr[i]));
ctxt->pStreamConversion = new cudaStream_t;
cudaStreamCreate(ctxt->pStreamConversion);
Capture Loop:
for(i = 0; i < 100; i++){
frame = UniqueObj<Frame>(iFrameConsumer->acquireFrame(40000000, &status));
if (status != STATUS_OK)
continue;
try
iFrame = interface_cast<IFrame>(frame);
iNativeBuffer = interface_cast<NV::IImageNativeBuffer>(iFrame->getImage());
status = iNativeBuffer->copyToNvBuffer(fd);
if (status != STATUS_OK){
cout << "Copy to NVbuffer failed" << endl;
continue;
frame.reset();
int dmaFd = context.dstDmaFd[i % maxBuffers];
nvRet = NvBufSurf::NvTransform(&tParams, fd, dmaFd);
if (nvRet != 0){
cout << "RGBA conversion failed" << endl;
continue;
CUeglFrame *eglFrame = context.dmaEglMap.find(dmaFd)->second;
int offs[] = {0, 0, 0};
convertEglFrameIntToFloat(eglFrame, eglFrame->width, eglFrame->height,
COLOR_FORMAT_RGB, mBuf, offs, offs, context.pStreamConversion);
cudaError_t res = cudaStreamSynchronize(*context.pStreamConversion);
if (res != cudaError_t::cudaSuccess){
std::cout << "Error conversion";
break;
catch(...)
std::cout << "Image manipulation error\n";
I am getting error at cudaError_t res = cudaStreamSynchronize(*context.pStreamConversion);
Am I missing something in the configuration?
