CUDA memory alignment performance and wrong output results
I tried to understand the GPU memory alignment mechanism by following the official cuda samples released from Nvidia. In the demo code, there are three types struct as the following .
typedef struct {
unsigned char r, g;
} RGBA8_misaligned;
typedef struct align(16) {
unsigned int r, g, b, a;
RGBA32;
RGBA32 c1, c2;
RGBA32_2;
What we are trying to do is to copy the data from one array to the other as the following code, where the TData is the type of data structure I mentioned above.
template
global void testKernel(TData *d_odata, TData *d_idata, int numElements) {
const int tid = blockDim.x * blockIdx.x + threadIdx.x;
const int numThreads = blockDim.x * gridDim.x;
for (int pos = tid; pos < numElements; pos += numThreads) {
d_odata[pos] = d_idata[pos];
In the experiments, we allocate the same memory on the target device. My GPU card is V100 16GB and the code can be checked on this link GitHub - NVIDIA/cuda-samples: Samples for CUDA Developers which demonstrates features in CUDA Toolkit from last commit and the file name is called alignedTypes. The experiment results are as the following:
RGBA8_misaligned…
Number of elements in array 24999936
Avg. time: 0.730656 ms / Copy throughput: 63.731760 GB/s.
TEST FAILURE
RGBA32…
Number of elements in array 3124992
Avg. time: 0.153781 ms / Copy throughput: 302.806808 GB/s.
TEST OK
RGBA32_2…
Number of elements in array 1562496
Avg. time: 0.203812 ms / Copy throughput: 228.474753 GB/s.
TEST OK
I have two questions.
  1. If we only put two unsigned chars into the structure like RGBA8_misaligned, it cannot be copied successfully.
  2. The throughput of RGBA32_2 is much lower than RGBA32. I do not get the exact reason.
