Hi NVIDIA Forum,
iam using CUDA.NET.
I have a Problem with the code. But i dont know why it doesnt work. On my Notebook it works fine, but on the desktop it crashes when i call the launch function.
I my notebook i have a geforce gt330m und in the desktop there is a gtx480.
It would be greatful if someone can help me.
Here is my code:
Program.cs
using System;
using System.Collections.Generic;
using System.Text;
using GASS.CUDA;
using GASS.CUDA.Types;
using System.IO;
namespace bitonic
class Program
static void Main(string[] args)
const int NUM = 256;
// Init CUDA, select 1st device.
CUDA cuda = new CUDA(0, true);
// create values
int[] values = new int[NUM];
for (int i = 0; i < NUM; i++)
values[i] = i;
// allocate memory and copy to device
CUdeviceptr dvalues = cuda.CopyHostToDevice<int>(values);
// load module
cuda.LoadModule(Path.Combine(Environment.CurrentDirectory, "test.cubin"));
CUfunction func = cuda.GetModuleFunction("square");
cuda.SetParameter(func, 0, (uint)dvalues.Pointer);
cuda.SetParameterSize(func, (uint)IntPtr.Size);
//square<<<1, NUM, sizeof(int) * NUM>>>(dvalues);
cuda.SetFunctionBlockShape(func, NUM, 1, 1);
cuda.SetFunctionSharedSize(func, sizeof(int) * NUM);
cuda.Launch(func, 1, 1);
//Test doesnt work too
//cuda.Launch(func);
cuda.CopyDeviceToHost<int>(dvalues, values);
cuda.Free(dvalues);
Console.WriteLine(values[i]);
Console.Read();
test.cu
extern "C" __global__ void square(int * values)
int NUM = 256;
int tid = threadIdx.x;
if(tid < NUM)
values[tid] = values[tid] * values[tid];
The error comes when i call "cuda.Launch(func, 1, 1); with the Exception GASS.CUDA.CUResult.ErrorLaunchOutOfResources.
I run my compiler with this postbuildcomand “C:\Program Files (x86)\NVIDIA GPU Computing Toolkit\CUDA\v3.1\bin\nvcc.exe” test.cu -arch=sm_20 --cubin -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\bin”.
Thanks for your help in advance
greetz
markus
