Hi all
I’m trying to help some geoscientists trial trial CUDA from fortran. When I run the attached code (called from fortran) I get these error messages:
In function ‘cu_fft_1d_r2c_’
- plan created
- about to execute plan
cufft: ERROR: /root/cuda-stuff/sw/rel/gpgpu/toolkit/r2.0/cufft/src/cufft.cu, line 115
cufft: ERROR: CUFFT_INVALID_PLAN - plan executed
cufft: ERROR: /root/cuda-stuff/sw/rel/gpgpu/toolkit/r2.0/cufft/src/cufft.cu, line 94
Leaving function ‘cu_fft_1d_r2c_’
amplitude of bp filter at 0.5 transmitter base= (0.9961086,0.000000)
In function ‘cu_fft_1d_c2r_’ - about to execute plan
- plan created
Leaving function ‘cu_fft_1d_c2r_’
I understand the ‘cufft: ERROR: /root/cuda-stuff/sw/rel/gpgpu/toolkit/r2.0/cufft/src/cufft.cu’ part, my code does not live in this directory so I figure thats where the NVidia coder was working.
The ‘line 115’ error occurs when executing the plan.
The ‘line 94’ error occurs when destroying the plan.
I’ve read the CUFFT Library 2.0 PDF but I can’t spot what I’m doing wrong with the plan.
in the fortran code, I call my functions by ‘call cu_fft_1d_r2c(pt_series,dt_series,n)’ and ‘call cu_fft_1d_c2r(pt_series,dt_series,n)’.
I have two quadro FX5600’s in my workstation (SLI bridge attached but SLI not configure in X - I’m on a RedHat EL5.2 workstation).
Can someone please assist?
Thanks in advance.
CC
cudafunction.cu.txt (2.96 KB)
