I am trying to debug my CUDA application using the Jetson TX1 but when I launch the debugger I encounter this problem.
I tried to access to the host using the command “(cuda-gdb) target remote …” and I got the same problem: “No se puede matar el proceso” (The process cannot be killed").
Thank you for reading.
