Is it possible to run Nsight in a guest Ubuntu VM?
Nsight can definitely be ran under VM but not all features would be enabled there. You will be able to use source editing, build support, version control systems integration by debugging and profiler will not work as they require low-level access to GPU that is not available from VM.
