I would like to do some CUDA development on my alienware m11xR2 laptop (the one with the dreaded optimus…i.e. no linux support from nvidia…). Actually, I bought it for work and I NEED to do some CUDA on it…
It has the NVIDIA Geforce 335M which I am pretty sure has CUDA support.
I have Win7-64 bit OS.
I have downloaded and tried to install the latest developer driver, devdriver_3.2_winvista-win7_64_260.61_notebook, but when I try to install it, it says that no supported hardware can be found.
What are my options? Am I trying to install the wrong driver?
Surely this is possible. I mean… I know linux isn’t supported but this is Windows 7…
Yes, install the release and not the developer drivers ( the ones accessible directly from the NVIDIA home page ). You should have no problems running CUDA programs on this laptop, I have one myself. It is worth reading the developer notes for Optimus platforms, however.
Incidentally, CUDA will work on the Alienware11xR2 with Linux, but I have experienced permissions issues. ie, the SDK samples must be initially run as root in oder to work. I’m waiting for a reply from NVIDIA on the explanation/solution for this.
I have an alienware M11x R2 and I am having a bad time trying do install cuda and made it work, i.e. compile and have the executable files to recognize the NVIDIA device. How did you manage to have cuda working?
Install the 260.19 developer drivers. Opt not to modify your X config ( this will not work as the driver does not support using the NVIDIA card as a display device )
Install the nvidia module with modprobe ( may or may not be necessary ).
Install the CUDA Toolkit. Modify your startup file (.bashrc or whatever) to add the location of the cuda libraries to LD_LIBRARY_PATH
Install the SDK
Compile the cuda utils and deviceQuery sample in the SDK. If this doesn’t work you’ve done something wrong.
Install the SDK
Did anybody got any feedback from nvidia regarding this issue?
Also when the laptop goes on standby, that completely shut down cuda, nothing works anymore. I have to rmmod nivia, modprobe nvidia and rerun the devuiceQuery as a root.
I completed the installation, and it passed the deviceQuery test.
But it cant execute the volumeRender or the fluidsGL executable,probably because I haven’t replaced the Xorg file, but if I do then the computers bugs itself. So to get it straight CUDA is allowed as long as there is no GL output?
Btw : The error I receive when I try to run the GL executables is this:
Xlib: extension “GLX” missing on display “:0.0”.
freeglut (./volumeRender): OpenGL GLX extension not supported by display ‘:0.0’
