cuda on gtx295 coop help.
Hi! I need help. I got 2 gtx 295 coop on sli. pc wizard says i dont have cuda. I tried installing it from nvidia, but no change. Is cuda nesesary for gaming, benchmarks or i it for comercial use only. my driver is 190.62 whql. Please help. I’m a noob.
CUDA is probably, in it’s current state-of-the-art, good for massive parallel computing not related to games. I know some games have CUDA stuff going on, but for the most part you won’t need the CUDA driver. Your games will run just fine (maybe better?) with the normal non-cuda driver…
If you’re not developing with CUDA or using any specific CUDA apps (you’d know if you were) then just use the regular driver.
Matt
