I have some questions related to CUDA and other Libraries. We build/customize L4T BSP to create our own board specific BSP Image from the source and we flash eMMC.
1)Can we include or exclude CUDA while building from source? by making changes to makefile or something? Or by default it will be included in the BSP?
2)Can we use jetpack itself without flashing the OS and drivers to install packages after flashing the eMMC? If I do so will that alter my driver or OS?
Can I install these Libraries once I flash the BSP and it is up and running using commands?
What is the best way you suggest to install/add CUDA or other libraries if I build BSP from sources?
5)Can users create target images by incorporating user-developed software into the BSP later?
hi venkatraman.bhat:
CUDA is not default in BSP, it is installed after OS installed
yes ,you can select install Jetson SDK Componetns only with sdkmanager
