cuda on mbp w/9400m & 9600gt
I have an early unibody MBP with 9400M and 9600GT. Latest SDK with latest CUDA drivers only enumerate 9600. I read in this forum that in osx, it is possible to access both of the devices. Is it also possible in linux (unbuntu 9.10 32Bit in this case) ?
CUDA Device Query (Runtime API) version (CUDART static linking)
There is 1 device supporting CUDA
Device 0: "GeForce 9600M GT"
  CUDA Driver Version:						   3.0
  CUDA Runtime Version:						  3.0
  CUDA Capability Major revision number:		 1
  CUDA Capability Minor revision number:		 1
  Total amount of global memory:				 536150016 bytes
  Number of multiprocessors:					 4
  Number of cores:							   32
  Total amount of constant memory:			   65536 bytes
  Total amount of shared memory per block:	   16384 bytes
  Total number of registers available per block: 8192
  Warp size:									 32
  Maximum number of threads per block:		   512
  Maximum sizes of each dimension of a block:	512 x 512 x 64
  Maximum sizes of each dimension of a grid:	 65535 x 65535 x 1
  Maximum memory pitch:						  2147483647 bytes
  Texture alignment:							 256 bytes
  Clock rate:									1.25 GHz
  Concurrent copy and execution:				 Yes
  Run time limit on kernels:					 Yes
  Integrated:									No
  Support host page-locked memory mapping:	   No
  Compute mode:								  Default (multiple host threads can use this device simultaneously)
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 134564343, CUDA Runtime Version = 3.0, NumDevs = 1, Device = GeForce 9600M GT
PASSED
