Hi All,
I have two independent threads and both of them are using CUDA OpenGL interop. My problem is that cudaGLMapBufferObject() hangs when calling from second thread, and after some time blue screen occurs and machien restarts. If CUDA OpenGL inerop is removed from first thread, then the second thread will work fine. could not see such restriction is specified anywhere. Is this a bug of CUDA OpenGL interop?
Code of first thread is as follows,
[codebox]
DWORD WINAPI Thread1( LPVOID lpParameter )
HDC hDC =0;
HGLRC hRc = 0;
init( hDC, hRc );
cudaError_t nCudaError = cudaGLSetGLDevice( 0 );
UINT uBufferID = CreateBuffer();
BYTE* pbyInputData = 0;
nCudaError = cudaGLRegisterBufferObject( uBufferID );
nCudaError = cudaGLMapBufferObject( ( void** )&pbyInputData, uBufferID );
// My Kernel goes here
nCudaError = cudaGLUnmapBufferObject( uBufferID );
nCudaError = cudaGLUnregisterBufferObject( uBufferID );
// Notify second thread to start processing
SetEvent( g_hEvent );
return 0;
[/codebox]
Code for second thread is given below,
[codebox]
DWORD WINAPI Thread2( LPVOID lpParameter )
HDC hDC =0;
HGLRC hRc = 0;
init( hDC, hRc );
// Wait for first thread to finish using CUDA
WaitForSingleObject( g_hEvent, INFINITE );
return 0;
[/codebox]
This code does not contain any kernel, but the problem can be easily seen without the kernels !
I am using Win XP, CUDA 2.0, NVIDIA GeForce 8600 GTS, Display driver version - 178.28. Please help me to solve the issue.
