I just did a test with the Simple OpenGL sample in the SDK on a system with two GPUs - Quadro FX 4600 & GeForce GT 220.
Only one monitor is attached to either one of the GPU at any given time.
Test Case 1
Quadro was selected with cudaGLSetGLDevice().
Monitor is attached to Quadro.
Result frame rate: 60 fps.
Test Case 2
Monitor is attached to GeForce.
Result frame rate: 400 fps.
Test Case 3
GeForce was selected with cudaGLSetGLDevice().
Test Case 4
Now, interesting results.
This makes me wonder how the memory was allocated on the devices.
And I came up with this hypothesis:
- OpenGL memory are allocated on all devices.
- CUDA result is written to all memory allocated on different GPU at the same time.
- The GPU connected to the monitor renders on the screen.
Someone please help me verify this.
Is the above correct or I am very wrong?
Thank you.
