# CUDA -OpenGL Interop
**URL:** <https://forums.developer.nvidia.com/t/cuda-opengl-interop/26512>\
**Category:** CUDA Programming and Performance\
**Created:** [April 27, 2012, 6:34pm UTC](https://forums.developer.nvidia.com/t/cuda-opengl-interop/26512 "2012-04-27T18:34:06Z")\
**Posts on this page:** 1\
**Page:** 1
<div class="post-metadata">
**Author:** ![genetic\_priest](https://developer.download.nvidia.com/images/forums/profile-default-devtalk-84.png) [@genetic\_priest](https://forums.developer.nvidia.com/u/genetic_priest)\
**Post date:** [April 27, 2012, 6:34pm UTC](https://forums.developer.nvidia.com/t/cuda-opengl-interop/26512/1 "2012-04-27T18:34:06Z")
</div>
Hi All!
I’ve got a problem with using renderbuffer in CUDA kernel. My task is:
1. Render image in some position to renderbuffer.
2. Get image and process it pixel-by-pixel.
So I create and bind all buffers:
```auto
rbo = new GLRBO(GL_RGBA, mesh->size.Max[0] - mesh->size.Min[0], mesh->size.Max[1] - mesh->size.Min[1]);
    fbo = new GLFBO(GL_COLOR_ATTACHMENT0, rbo->GetId());
    vao = new GLVAO(1, &BufferIds[0]);
    vao->Bind();
    vbo = new GLVBO(2, &BufferIds[1]);
    vbo->Bind(GL_ARRAY_BUFFER);
    vbo->SetData(GL_ARRAY_BUFFER, sizeof(GLVertex)*(mesh->nVertices+1), vertices, GL_DYNAMIC_DRAW);
    vbo->Bind(GL_ELEMENT_ARRAY_BUFFER);
    vbo->SetData(GL_ELEMENT_ARRAY_BUFFER, sizeof(GLuint)*mesh->nElements, indices, GL_DYNAMIC_DRAW);
    vao->Unbind();
    //register in CUDA
cudaSetDevice(0);
cudaGLSetGLDevice(0)
    cudaGraphicsResource* resource;
    cudaGraphicsGLRegisterImage(&resource, rbo->GetId(), GL_RENDERBUFFER, cudaGraphicsMapFlagsReadOnly);
cudaGraphicsMapResources(1, &resource, 0);
// ... Render image
void GLMain::_RenderScene()
    ++FrameCount;
    //render at maximum resolution to render buffer
    glViewport(0, 0, rboWidth, rboHeight);
if(!bDone)
        fbo->Bind();
        glClearColor(0.0, 0.0, 0.0, 1.0);
        glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
        DrawMesh();
        fbo->BindReadDraw();
        cudaArray* array;
        cudaGraphicsSubResourceGetMappedArray(&array, resource, 0, 0);
        size_t size = sizeof(float)*rboWidth*rboHeight;
        float* initData = (float*)malloc(size*4);
        memset(initData, 0, size*4);
        ProcessImage(ar, initData, rboWidth, rboHeight);
//Render to screen
//...... Process_Image.cu
texture <float4, cudaTextureType2D, cudaReadModeElementType> tex;
extern "C" void ProcessImage(cudaArray* in, float* _outAngle, float* _outIntence, float* _inData, int w, int h )
    cudaBindTextureToArray(tex, in);
    size_t size = sizeof(float)*w*h;
    float* inData;
    cudaMalloc(&inData, size*4);
    dim3 threads(16, 16);
    dim3 blocks(w/threads.x, h/threads.y);
    cuProcessKernel<<<blocks, threads>>>(inData, w, h);
    cudaThreadSynchronize();
    cudaUnbindTexture(tex);
    cudaMemcpy(_inData, inData, size*4, cudaMemcpyDeviceToHost);
    cudaFree(outAngle);
    cudaFree(outIntence);
//...Kernel
__global__ void cuProcessKernel(float* initialData, int w, int h)
    int	x = blockIdx.x*blockDim.x + threadIdx.x;
    int	y = blockIdx.y*blockDim.y + threadIdx.y;
    int	idx = y * w + x;
    float4 pix = tex2D(tex, x, y);
    initialData[idx*4] = pix.x;
    initialData[idx*4+1] = pix.y;
    initialData[idx*4+2] = pix.z;
    initialData[idx*4+3] = pix.w;
So I’m simply trying to get per-pixel image in float4 format. But instead I get some garbage in the output array. When I make all white image it returns incorrect values. Could someone tell me where is my mistake ?
System: OS Win 7 x64 SP1, Core i7 2600/GTX570/16Gb, CUDA Toolkit 4.2, devdriver\_4.2\_winvista-win7\_64\_301.32\_general.
