cuda opengl interoperation problem
I’m trying to use cudaPitchedPtr to write data to a 3d cudaArray, then map the cudaArray to openGL as GL_TEXTURE_2D_ARRAY.
In my shader I use imageLoad function to load data.
But the program doesn’t draw anything…
texture<float4, 3, cudaReadModeElementType> texState;
cudaArray *texArrayState;
cudaPitchedPtr writeablePitch;
void cloth::initTexture()
	texArrayState = 0;
	// create the texture array
	cudaChannelFormatDesc channelDesc = cudaCreateChannelDesc<float4>();
	cudaExtent volumeSize = make_cudaExtent(widthSize, heightSize, numberOfTexStateLayers);
	CUDA_SAFE_CALL(cudaMalloc3DArray(&texArrayState, &channelDesc, volumeSize) );
	CUDA_SAFE_CALL(cudaBindTextureToArray(texState, texArrayState, channelDesc));
	// create memory using a cudaPitchedPtr
	cudaExtent pitchedVolSize = make_cudaExtent(widthSize*sizeof(float4), widthSize, heightSize);
	CUDA_SAFE_CALL(cudaMalloc3D(&writeablePitch, pitchedVolSize));
	glGenTextures(1, &texObjState);
	glActiveTexture(GL_TEXTURE0 + stage);
	glBindTexture(GL_TEXTURE_2D_ARRAY, texObjState);
	glTexParameteri(GL_TEXTURE_2D_ARRAY, GL_TEXTURE_MIN_FILTER, GL_NEAREST);
	glTexParameteri(GL_TEXTURE_2D_ARRAY, GL_TEXTURE_MAG_FILTER, GL_NEAREST);
	glTexImage3D(GL_TEXTURE_2D_ARRAY, 0, GL_RGBA32F, widthSize, heightSize, numberOfTexStateLayers, 0, GL_RGBA, GL_FLOAT, 0);
	glBindImageTextureEXT(stage, texObjState, 0, true, 0,  GL_READ_WRITE, GL_RGBA32F);
	glBindTexture(GL_TEXTURE_2D_ARRAY, 0);
	CUDA_SAFE_CALL(cudaGraphicsGLRegisterImage(&resourceState, texObjState, GL_TEXTURE_2D_ARRAY, cudaGraphicsMapFlagsNone));
	CUDA_SAFE_CALL(cudaGraphicsMapResources(1, &resourceState, NULL));
	CUDA_SAFE_CALL(cudaGraphicsSubResourceGetMappedArray(&texArrayState, resourceState, 0, 0));
void cloth::initClothState()
	float2 clothSize = make_float2(widthSize, heightSize);
	float3 pos = make_float3(position.x, position.y, position.z);
	dim3 blocks(widthSize/blockSize, heightSize/blockSize);
	dim3 threads(blockSize, blockSize);
	initState<<<blocks, threads>>>(writeablePitch, clothSize, length, pos);  // call the kernel to initialize the position of cloth
	// set parameters for copyParams
	cudaMemcpy3DParms copyParams = {0};
	copyParams.srcPtr = writeablePitch;
	copyParams.dstArray = texArrayState;
	copyParams.kind = cudaMemcpyDeviceToDevice;
	copyParams.extent = make_cudaExtent( widthSize, heightSize, numberOfTexStateLayers);
	CUDA_SAFE_CALL(cudaMemcpy3D(&copyParams));  // copy data from cudaPitchedPtr to cudaArray
__global__ void initState(cudaPitchedPtr cpp, float2 clothSize, float clothWidthLength, float3 centerPos)
	int x = threadIdx.x + blockIdx.x * blockDim.x;
	int y = threadIdx.y + blockIdx.y * blockDim.y;
	if(x >= clothSize.x || y >= clothSize.y)
		return;
	int offset =x + y * clothSize.x;
	float cellSize = clothWidthLength / (clothSize.x - 1);
	float boundaryWidth_length = clothWidthLength;
	float boundaryHeight_length = cellSize * (clothSize.y - 1);
	float3 start_corner = make_float3(centerPos.x - boundaryWidth_length/2.0, centerPos.y, centerPos.z + boundaryHeight_length/2.0);
	float3 particlePos = make_float3(start_corner.x + x * cellSize, start_corner.y, start_corner.z - y * cellSize);
	// initialize positions
	((float4 *)cpp.ptr)[offset] = make_float4(particlePos.x, particlePos.y, particlePos.z, .0f);
I don’t know what wrong it is.
anyone can help me out?
million thanks!
I’m not sure if 2D texture arrays are supported for OpenGL interop (they use a different layout than 3D textures). Does it work with GL_TEXTURE_3D?
i’ve checked the nvidia doc about OpenGL Interoperability.
the list includes GL_TEXTURE_2D_ARRAY.
I solved the problem by renaming main.cpp.cu to main.cpp.
In my main file, the cloth object is created by “new” (clothObj = new cloth(…)).
I found that the “new” doesn’t work correctly in cu file…
dont know why…really strange
