Have anyone tried to use PAPI CUDA component on Jetson TK1? Is it even possible to use it with CUDA core on this board?
https://developer.nvidia.com/papi-cuda-component
I was able to use it before on desktop to measure power consumption from CUDA cores on Nvidia video card. I would really want to do the same with Nvidia Jetson boards.
I am trying to install PAPI, but when I attempt to configure CUDA component of PAPI I am getting following error about missing cudart:
checking for cudaMalloc in -lcudart... no
configure: error: Library cudart not found
libcudart.so is in lib directory of CUDA-6-0.
ubuntu@tegra-ubuntu:/usr/local/cuda/lib$ ls
libcublas_device.a libcufftw.so libnppc.so
libcublas.so libcufftw.so.6.0 libnppc.so.6.0
libcublas.so.6.0 libcufftw.so.6.0.42 libnppc.so.6.0.42
libcublas.so.6.0.42 libcuinj32.so libnppi.so
libcudadevrt.a libcuinj32.so.6.0 libnppi.so.6.0
libcudart.so libcuinj32.so.6.0.42 libnppi.so.6.0.42
libcudart.so.6.0 libcurand.so libnpps.so
libcudart.so.6.0.42 libcurand.so.6.0 libnpps.so.6.0
libcudart_static.a
My bashrc file
# CUDA 6.0
export PATH=$PATH:/usr/local/cuda-6.0/bin
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/cuda-6.0/lib
# CUPTI
export PATH=$PATH:/usr/local/cuda-6.0/extras/CUPTI
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/cuda-6.0/extras/CUPTI/lib
