Hi, I’ve created a N-body charged particle simulation that uses CUDA for the calculations and SDL for the rendering, but the problem is I can’t seem to get all the particles to interact with each other. Only certain groups of particles seem to actually apply force on each other, like I can see two particles basically touching withouting having any sort of effect, while other particles display the correct behaviour. I know my actually physics algorithm works, because I got it to work pn the CPU, its just the parallel GPU computation that doesn’t seem to work…
I run the function with N blocks and N threads, where i is the block number and j is the thread number, then I apply the forces of particle array[j] on particle array[i] where i != j.
I won’t supply all my code as it’s all bundled in one file right now with a whole load of irelivent SDL code, so I will just supply the main loop and the physics() function
__global__ void physics( particle *arr )
double force;
double forceT;
double temp;
double dx, dy;
double r;
unsigned int i = blockIdx.x;
unsigned int j = threadIdx.x;
if( i != j )
temp = ( KE * arr[i].charge * arr[j].charge );
dx = - arr[i].x + arr[j].x;
dy = - arr[i].y + arr[j].y;
r = sqrt( dx * dx + dy * dy );
force = temp / ( r * r );
forceT = atan2( dy , dx );
arr[i].xv += -force * cos( forceT ) / arr[i].mass * DT;
arr[i].yv += -force * sin( forceT ) / arr[i].mass * DT;
arr[i].x += arr[i].xv*DT;
arr[i].y += arr[i].yv*DT;
while( running && mainEvent->type != SDL_QUIT )
//Polls for new events (?)
SDL_PollEvent( mainEvent );
//Nuke the window
SDL_RenderClear( renderer );
cu_MEMCOPY_D( particle, pArr, N );
physics<<<N,N>>>( d_pArr );
cu_MEMCOPY_H( particle, pArr, N );
renderParticles( h_pArr, N, renderer );
//Render new frame
SDL_RenderPresent( renderer );
Be warned I made a few macros for allocation and copying between the host and the device, so please dont hate me for using macros.
Is there any light you can shed possible on my problem?
