There are at least a few issues.
In C++, when you pass a variable to a function via the function parameters, a copy of that variable is made for local use by the function. Any modifications made to that variable will not show up globally, i.e. in the calling environment, because the function is operating on a copy of the variable. Therefore this could never do what you want:
d_world = new make_list(&d_list, num_triangles);
There is nothing illegal about it, per se, but it will not have the desired effect. The global copy of
d_world
is unchanged by that assignment. This is a C++ concept, not unique or specific to CUDA, and it trips people up from time to time. -
This is almost never legal in CUDA:
render << <1, 1 >> > (&d_world); ^
In typical usage, it is not possible to pass the address of a host location to device code via a kernel call parameter. Any attempt to dereference that pointer
&d_world
will result in dereferencing the address of a host location. That is illegal in CUDA device code. -
While not necessarily a problem at this point, you should be aware of the fact that in-kernel
new
operates against the device heap which has a default limit of 8MB, and furthermore allocations created this way cannot take part in host-issued cudaMemcpy* calls. These topics are covered in the programming guide.
When I make changes to address those first 2 items, I get what appear to be sensible results:
$ cat t2190.cu
#include <cuda_runtime.h>
#include <device_launch_parameters.h>
#include <vector>
#include <cstdio>
struct make_list {
__device__ make_list(float* list, int n) { contents = list; size = n; };
float* contents;
int size;
__global__ void render(make_list** world) {
int size = (*world)->size; // set a breakpoint here, the size is 0
printf("size = %d\n", size);
__global__ void create_world(float* d_list, make_list** d_world, int num_triangles) {
if (threadIdx.x == 0 && blockIdx.x == 0) {
// the class hittable_list contains a counter for the list size, which no matter the
// scene size it always becomes zero
*d_world = new make_list(d_list, num_triangles);
int main () {
float* d_list;
make_list** d_world;
cudaMalloc(&d_world, sizeof(make_list*));
int size = 8;
std::vector<float> m_triangles(size);
cudaMalloc((void**)&d_list, size * sizeof(float));
cudaMemcpy(d_list, m_triangles.data(), size * sizeof(float), cudaMemcpyHostToDevice);
create_world << <1, 1 >> > (d_list, d_world, size);
cudaDeviceSynchronize();
render << <1, 1 >> > (d_world);
return 0;
$ nvcc -o t2190 t2190.cu
$ compute-sanitizer ./t2190
========= COMPUTE-SANITIZER
size = 8
========= ERROR SUMMARY: 0 errors
(Yes, I have changed your handling of d_list
/contents
as well, and indicated the reasons why on my answer on your cross posting.)
