Hi!
I could not generate the cuda_profile.log file.
FYI:
*) The system env.var. CUDA_PROFILE was set to 1
*) I am calling Kernels from an exe which loads a dll and this dll loads a 2nd dll with “cuda kernel” functions
Are you sure you started the EXE after you set the environment variable?
Did you look around in different places because the profiler log is created in the “current directory” by default and that could pretty much anywhere? (Maybe setting the path via the environment variable might help).
