I and running profiler, it runs ok but at the end it gives the message:
Error -94 in reading profiler output.
Minimum expected columns (method, gputime, cputime, occupancy) not found in profiler output file.
Any ideas - thank you
your program either does not exit (and the profiler kills it after the time you tell it to wait
or your program changes the current directory before launching a kernel (and the profiler expected it in the directory that was current before launching the program.
Try tp put --noprompt in the argument of the session settings (Profile -> session settings). It has worked for me :)
The CUT_EXIT macro expects user to press enter. That’s why with the profiler, you should use --noprompt option.
