My very simple program is taking a long time to launch. I’ve upgraded to the latest driver, and also enabled persistence mode. This issue can also be found when I run use some vscode extension that may utilize GPU. The hang seems only happen at launch time, so I use strace to check which op takes that much time, and found that 1 ioctl tooks 24s!!
My GPU settings is as below:
| NVIDIA-SMI 530.41.03 Driver Version: 530.41.03 CUDA Version: 12.1 |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 3090 On | 00000000:01:00.0 On | N/A |
| 31% 44C P5 39W / 350W| 1021MiB / 24576MiB | 29% Default |
| | | N/A |
| 1 NVIDIA GeForce RTX 3090 On | 00000000:07:00.0 Off | N/A |
| 30% 31C P8 7W / 350W| 6MiB / 24576MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1062 G /usr/lib/Xorg 275MiB |
| 0 N/A N/A 1156 G /usr/bin/gnome-shell 62MiB |
| 1 N/A N/A 1062 G /usr/lib/Xorg 4MiB |
And here is the strace logs.
testrun.log (105.3 KB)
Could you please help to check what’s the issue?
