CUDA ptx file generation for driver API fails
Hi, I’ve been playing around with the driver API, but I’m having a problem with creating modules. Below is my code that loads the module:
int main() {
	CUDA_ASSERT(cuInit(0));
	// Device
	CUdevice device;
	CUDA_ASSERT(cuDeviceGet(&device, 0));
	// Context
	CUcontext context;
	CUDA_ASSERT(cuCtxCreate(&context, 0, device));
	// Module
	CUmodule module;
	CUDA_ASSERT(cuModuleLoad(&module, "kernel.ptx"));
	// Free context
	CUDA_ASSERT(cuCtxDestroy(context));
I have the following project structure:
project
* kernel.cu
* main.cpp
kernel.cpp looks like this (note that this is the entire file):
#include <cstdio>
__global__ void run_kernel() {
	printf("kernel running\n");
I have added the --ptx option to NVCC via Configuration Properties → CUDA/C++ → Command Line → Additional Options and I have linked against cuda.lib. I think I’ve done everything correctly, but whenever I compile I get an LNK1107 Invalid or corrupt file: cannot read at 0x8B1 error - how can I fix this? Thanks.
Solved it by using the following arguments: -Xcompiler “/wd 4819” --threads 0
