In our RedHat Linux server we have installed NVIDIA. During the server updates we have received a number of CUDA Issues. For more information you could read the below logs :
Error:
Problem 1: package nvidia-open-3:560.28.03-1.noarch from cuda-rhel9-x86_64 requires nvidia-kmod >= 3:560.28.03, but none of the providers can be installed
- cannot install the best update candidate for package cuda-drivers-555.42.06-1.x86_64
- package kmod-nvidia-latest-dkms-3:560.28.03-1.el9.x86_64 from cuda-rhel9-x86_64 is filtered out by modular filtering
- package kmod-nvidia-open-dkms-3:560.28.03-1.el9.x86_64 from cuda-rhel9-x86_64 is filtered out by modular filtering
Problem 2: package nvidia-kmod-common-3:560.28.03-1.el9.noarch from cuda-rhel9-x86_64 requires nvidia-kmod = 3:560.28.03, but none of the providers can be installed - cannot install the best update candidate for package nvidia-kmod-common-3:555.42.06-1.el9.noarch
Problem 3: package cuda-12.6.0-1.x86_64 from cuda-rhel9-x86_64 requires nvidia-open >= 560.28.03, but none of the providers can be installed - package nvidia-open-3:560.28.03-1.noarch from cuda-rhel9-x86_64 requires nvidia-kmod >= 3:560.28.03, but none of the providers can be installed
- cannot install the best update candidate for package cuda-12.5.1-1.x86_64
Problem 4: package nvidia-driver-3:560.28.03-1.el9.x86_64 from cuda-rhel9-x86_64 requires nvidia-kmod-common = 3:560.28.03, but none of the providers can be installed - package nvidia-kmod-common-3:560.28.03-1.el9.noarch from cuda-rhel9-x86_64 requires nvidia-kmod = 3:560.28.03, but none of the providers can be installed
- cannot install the best update candidate for package nvidia-driver-3:555.42.06-1.el9.x86_64
Problem 5: package nvidia-driver-cuda-3:560.28.03-1.el9.x86_64 from cuda-rhel9-x86_64 requires nvidia-kmod-common = 3:560.28.03, but none of the providers can be installed - package nvidia-kmod-common-3:560.28.03-1.el9.noarch from cuda-rhel9-x86_64 requires nvidia-kmod = 3:560.28.03, but none of the providers can be installed
- cannot install the best update candidate for package nvidia-driver-cuda-3:555.42.06-1.el9.x86_64
Problem 6: package nvidia-driver-3:560.28.03-1.el9.x86_64 from cuda-rhel9-x86_64 requires nvidia-kmod-common = 3:560.28.03, but none of the providers can be installed - package nvidia-settings-3:560.28.03-1.el9.x86_64 from cuda-rhel9-x86_64 requires nvidia-driver(x86-64) = 3:560.28.03, but none of the providers can be installed
- cannot install the best update candidate for package nvidia-settings-3:555.42.06-1.el9.x86_64
Problem 7: package nvidia-driver-cuda-3:555.42.06-1.el9.x86_64 from @System requires nvidia-driver-cuda-libs(x86-64) = 3:555.42.06, but none of the providers can be installed - package cuda-drivers-555.42.06-1.x86_64 from @System requires nvidia-driver-cuda >= 3:555.42.06, but none of the providers can be installed
- package nvidia-driver-cuda-3:560.28.03-1.el9.x86_64 from cuda-rhel9-x86_64 requires nvidia-kmod-common = 3:560.28.03, but none of the providers can be installed
- cannot install both nvidia-driver-cuda-libs-3:560.28.03-1.el9.x86_64 from cuda-rhel9-x86_64 and nvidia-driver-cuda-libs-3:555.42.06-1.el9.x86_64 from @System
- package cuda-runtime-12-1-12.1.1-1.x86_64 from @System requires cuda-drivers >= 530.30.02, but none of the providers can be installed
- package cuda-drivers-3:560.28.03-1.x86_64 from cuda-rhel9-x86_64 requires nvidia-kmod >= 3:560.28.03, but none of the providers can be installed
- cannot install the best update candidate for package nvidia-driver-cuda-libs-3:555.42.06-1.el9.x86_64
- cannot install the best update candidate for package cuda-runtime-12-1-12.1.1-1.x86_64
- package cuda-drivers-530.30.02-1.x86_64 from cuda-rhel9-x86_64 is filtered out by modular filtering
- package cuda-drivers-535.104.05-1.x86_64 from cuda-rhel9-x86_64 is filtered out by modular filtering
- package cuda-drivers-535.104.12-1.x86_64 from cuda-rhel9-x86_64 is filtered out by modular filtering
- package cuda-drivers-535.129.03-1.x86_64 from cuda-rhel9-x86_64 is filtered out by modular filtering
- package cuda-drivers-535.154.05-1.x86_64 from cuda-rhel9-x86_64 is filtered out by modular filtering
- package cuda-drivers-535.161.07-1.x86_64 from cuda-rhel9-x86_64 is filtered out by modular filtering
- package cuda-drivers-535.161.08-1.x86_64 from cuda-rhel9-x86_64 is filtered out by modular filtering
- package cuda-drivers-535.183.01-1.x86_64 from cuda-rhel9-x86_64 is filtered out by modular filtering
- package cuda-drivers-535.183.06-1.x86_64 from cuda-rhel9-x86_64 is filtered out by modular filtering
- package cuda-drivers-535.54.03-1.x86_64 from cuda-rhel9-x86_64 is filtered out by modular filtering
- package cuda-drivers-535.86.10-1.x86_64 from cuda-rhel9-x86_64 is filtered out by modular filtering
- package cuda-drivers-545.23.06-1.x86_64 from cuda-rhel9-x86_64 is filtered out by modular filtering
- package cuda-drivers-545.23.08-1.x86_64 from cuda-rhel9-x86_64 is filtered out by modular filtering
- package cuda-drivers-550.54.14-1.x86_64 from cuda-rhel9-x86_64 is filtered out by modular filtering
- package cuda-drivers-550.54.15-1.x86_64 from cuda-rhel9-x86_64 is filtered out by modular filtering
- package cuda-drivers-550.90.07-1.x86_64 from cuda-rhel9-x86_64 is filtered out by modular filtering
- package cuda-drivers-555.42.02-1.x86_64 from cuda-rhel9-x86_64 is filtered out by modular filtering
- package cuda-drivers-555.42.06-1.x86_64 from cuda-rhel9-x86_64 is filtered out by modular filtering
- package nvidia-driver-cuda-3:555.42.06-1.el9.x86_64 from cuda-rhel9-x86_64 is filtered out by modular filtering
- package nvidia-driver-cuda-libs-3:555.42.06-1.el9.x86_64 from cuda-rhel9-x86_64 is filtered out by modular filtering
- I’m sharing with you below CUDA information from in our server:
dnf info cuda
Updating Subscription Management repositories.
Last metadata expiration check: 0:51:26 ago on Wed 21 Aug 2024 09:34:56 AM EDT.
NVIDIA driver: some kernel packages have been filtered due to missing precompiled modules.
Please run “dnf nvidia-plugin” as a command to see a report on the filter being applied.
Installed Packages
Version : 12.5.1
Release : 1
Architecture : x86_64
Source : cuda-12.5.1-1.src.rpm
Repository : @System
From repo : cuda-rhel9-x86_64
Summary : CUDA meta-package
URL : http://nvidia.com
License : NVIDIA Proprietary
Description : Meta-package containing all the available packages required for native CUDA
: development. Contains the toolkit, samples, driver and documentation.
- From our troubleshooting We suspect that conflicting packages are in cuda repository only:
2.1.
cat sos_commands/dnf/dnf_list_installed | grep cuda| head <-=== Conflicting packages are in cuda repo only
cuda.x86_64 12.5.1-1 @cuda-rhel9-x86_64
cuda-12-1.x86_64 12.1.1-1 @cuda-rhel9-x86_64
cuda-12-2.x86_64 12.2.2-1 @cuda-rhel9-x86_64
cuda-12-3.x86_64 12.3.2-1 @cuda-rhel9-x86_64
2.2
repo id repo name
cuda-rhel9-x86_64 cuda-rhel9-x86_64 <===== This is cuda repo
epel Extra Packages for Enterprise Linux 8 - x86_64
packages-microsoft-com-prod packages-microsoft-com-prod
rhel-9-for-x86_64-appstream-rpms Red Hat Enterprise Linux 9 for x86_64 - AppStream (RPMs)
rhel-9-for-x86_64-baseos-rpms Red Hat Enterprise Linux 9 for x86_64 - BaseOS (RPMs)
disable all of the Cuda repositories, the updates complete without any issue. Enabling the Cuda repositories creates a number of modular dependency issues.
- So, If we disable the cuda repo. “cuda-rhel9-x86_64”, the updates complete without any issue. Enabling the cuda repositories creates a number of modular dependency issues.
Please, could you support us here, to fix this issue? We are in production servers and want to prevent this issue on our next servers updates
