I installed
NVIDIA-Linux-x86_64-177.73-pkg2.run
NVIDIA_CUDA_Toolkit_2.0_rhel5.1_x86_64.run
NVIDIA_CUDA_SDK_2.02.0807.1535_linux.run
on Red Hat Enterprise Linux Server release 5 x86-64.
I set PATH include /usr/local/cuda/bin and LD_LIBRARY_PATH include include /usr/local/cuda/lib.
The applications in …/project/ mostly can be make without error,except the application need -lglut because I don’t install it.
But,when I excute it ,geting some errors .
for example, when I excute devicequery, it is ok.
[root@localhost release]# ./deviceQuery
There is 1 device supporting CUDA
Device 0: “Quadro FX 3700”
Major revision number: 1
Minor revision number: 1
Total amount of global memory: 536608768 bytes
Number of multiprocessors: 14
Number of cores: 112
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1.24 GHz
Concurrent copy and execution: Yes
Test PASSED
Press ENTER to exit…
But ,error when excute other applications
[root@localhost release]# ./simpleCUFFT
Using device 0: Quadro FX 3700
cufft: ERROR: /root/cuda-stuff/sw/rel/gpgpu/toolkit/r2.0/cufft/src/config.cu, line 106
cufft: ERROR: CUFFT_INTERNAL_ERROR
cufft: ERROR: /root/cuda-stuff/sw/rel/gpgpu/toolkit/r2.0/cufft/src/cufft.cu, line 112
cufft: ERROR: CUFFT_INVALID_VALUE
Test FAILED
cufft: ERROR: /root/cuda-stuff/sw/rel/gpgpu/toolkit/r2.0/cufft/src/cufft.cu, line 94
cufft: ERROR: CUFFT_INVALID_PLAN
