THCudaCheck FAIL file=/media/nvidia/WD_BLUE_2.5_1TB/pytorch/aten/src/THCUNN/generic/SpatialDepthwiseConvolution.cu line=195 error=7 : too many resources requested for launch
File “train_ssd.py”, line 343, in
device=DEVICE, debug_steps=args.debug_steps, epoch=epoch)
File “train_ssd.py”, line 123, in train
loss.backward()
File “/usr/local/lib/python3.6/dist-packages/torch/tensor.py”, line 106, in backward
torch.autograd.backward(self, gradient, retain_graph, create_graph)
File “/usr/local/lib/python3.6/dist-packages/torch/autograd/init.py”, line 93, in backward
allow_unreachable=True) # allow_unreachable flag
RuntimeError: cuda runtime error (7) : too many resources requested for launch at /media/nvidia/WD_BLUE_2.5_1TB/pytorch/aten/src/THCUNN/generic/SpatialDepthwiseConvolution.cu:195
Thanks for your reply and sorry for late response. I flashed DLI AI sdk on the Jetson, recommended by the Nvidia tutorial. This has the Pytorch pre-built in it. Do you recommend me to uninstall this and re-build once again using the links?
It is inside the PyTorch source code. This patch was already applied to the PyTorch wheels (for PyTorch >= 1.1.0) if you are using one of the pre-built PyTorch wheels from this topic:
